- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 V2 Constant Random Reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 V2 Constant Random Reboots
What is the first 3 characters of the routers serial number please.
@Alansin wrote:
Can i get the firmware? same problem in late 2022
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello,
how to get the beta firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@trilist wrote:
hello,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated to the beta firmware. I have seen 1 reboot after the upload (3 days running time now). Will continue to monitor, but is night and day difference from previous .38 & .40 versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you factory reset and setup from scratch after loading the beta? Please do if you didn't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
the first 3 letters/numbers are
6K0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sent you a PM.
@Scaff wrote:
hi
6K0
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue and the same 3 first letters. Can I please have a beta firmware as well ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the brand and model# of the ISP modem your using with the router?
PM sent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is one of BT's Openreach modems, Huawei HG8240.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
Be sure your using good quality lan cable between the ONT and RAX router. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually, I got cat7 and cat8, so hopefully it is not an overkill 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing less that CAT6 would be recommended. 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ISP modem is a Hitron Model EN2251. The modem does not go down when the router does. Also, when we lose an internet connection via the modem, the wireless does not go away, just the internet connection.
My problem is the router keeps rebooting several times a day. At the suggestion of another community member and other online comments, I put the router on top of a laptop cooler with a fan. So the modem is being cooled from below.
I also keep checking to make sure I have the latest firmware/software updates from Netgear.
I've owned routers for over 20 years for my businesses and home and have never had as many problems with a new router as this one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Di you apply the beta FW that is to fix this reboot issue on the v2?
Others have already posted that this beta fixed this.
Thanks for the info about your modem.
Be sure you using a good quality LAN cable between the modem and router. CAT6 is best.
The mention of a USB laptop fan cooler is for the router, not the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
To be fair, itd be unfair to assume it’s the same problem given the length of time that’s passed, a reboot on its own after 24 days doesn’t necessitate the same problem or cause.
Not that I’m accepting of any sudden reboot (especially while I’m mid supplier review meeting on Teams!!!) NG need to do a lot better with their firmware across the board.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All continues to be good here. My system uptime is showing as 31:11:52:09.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would need to troubleshoot this to see if other contributing factors maybe causing a reboot other than FW not doing it's job. There are other factors that could cause a random reboot as well.
Would need more details on your Router configuration, ISP configuration and what's all connected to the router.
What was going on when you notice the reboot.
What did you see on the top of the router in regards to LED behaviors during this event.
Was ALL devices effected or just some?
@blakey84 wrote:
After what must have been 24-25 days I had my first reboot on the beta firmware today, after the router had processed over 1.8TB of data during that period from a very busy household.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A lot of troubleshooting going on here for what should be an inherently stable device.
My old NG router easily ran for six months at a time or longer on the same network configuration I have now.
The only change was the router. There is something about the RAX120 that isn't quite right.
But I will agree that it runs much better with the beta. 20 days and counting since the last reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And it still could be a stable router or something could be still causing a random reboot. Again, would need more details here.
Users are seeing 30 days on some so seems like something is stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I am having the same issue on RAX120v2, V1.2.8.40 (and previous releases). May I have a copy of the beta firmware to test please? First 3 of SN are 6JY - thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
TYVM. Connected to Arris SB6183 on xfinity service via cat6a. Will test with the beta firmware, appreciate it.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
