bubbagump210's avatar
bubbagump210
JGS524PE switch loses VLAN config on reboot
As the title says, I have a JGS524PE that loses it's VLAN configuration for a specific VLAN on a specific port on a reboot. I am running firmware 2.6.0.48. All other VLAN configs work perfectly fine. I saw in another post that port mirroring might cause this issue, but I have port mirroring disabled.  Port based basic and advanced are both disabled. 802.1Q basic is also disabled.
Here is a screen shot of my VLANs and the circled port is the one that simply won't stay.
  • schumaku's avatar
    schumaku
    Just curious: In 802.1q, VLAN Membership, Advanced - if adding yet another random VLAN with some ports marked as Tagged, does the issue remain on the previous config?
    • bubbagump210's avatar
      bubbagump210
      I just added VLAN 123 with various ports added as tagged ports. I rebooted and all settings remained EXCEPT for VLAN 50 on port 6.
      Before reboot:
      After reboot:
        bubbagump210
        As a next step, I deleted VLAN 50 and recreated it as before. The same behavior returned on port 6.
ProSupport for Business
