- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
readynas backblaze b2 problem connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am on OS 6.10.6. Every time I try to connect to Backblaze b2 via the s3 interface, I get an error "unable to read amazon bucket list." This is in the system log:
Dec 07 12:35:17 phoenix libngcsd[5955]: Curl returned error code 60. SSL peer certificate or SSH remote key was not OK
Dec 07 12:35:17 phoenix libngcsd[5955]: { Error type: 1, Exception: , Message: , HttpResponseCode: 0, ResponseBody: , Retryable: 1 }
I am using an access key with read and write permission. I am using a private bucket if that matters. I have triple checked that the url and keys are correct. Any ideas?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: readynas backblaze b2 problem connection
I have exactly the same problem. While it hasn't solved my issue, your S3/Backblaze key must have the listAllBucketNames permission.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I have determined that the readynas s3 code uses V2 security, and backblaze requires v4. I switched to using duplicity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Backblaze support seems to agree: "The requirement for V4 signatures is indeed a part of the S3 compatible API. The older versions have been deprecated and as a result, we have stopped supporting them. Unfortunately, I am not able to troubleshoot their device and it's utilities. I would recommend reaching out to their support to see if there is a way to update or alter the signature they are using. Apologies for not being able to be more help there."
We really need Netgear Support to chime in here with their viewpoint. Is Backblaze unusable with ReadyNAS forever? Does that mean other S3 interfaces will die as they stop accepting V2 signatures?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone heard back from NetGear on this issue?
I just noticed my Backblaze backup stopped around mid December without any error that I could see. I did upgrade the ReadyNAS OS around December 20th after that time and have since reverted to the Hotfix 1 which worked great for months. Now Backblaze won't work with the new OR the old OS.
I too contacted BackBlaze and they mentioned that we must be on V4. I think Backblaze changed something on their end, since I reverted to the older OS, it should work again but it doesn't.
Anyone have any ideas? Does anyone know where the logs are stored for the S3 backup section and I can see what the logs say when trying to connect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I don't own a product under warranty, I'm apparently cut off from any opportunity to communicate with Netgear support. All I hear about this significant problem is crickets...
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks like @JeraldM is a Moderator...was there any movement on this? As of now, the built-in S3 Cloud app on the ReadyNAS is completely broken due to the change in Signature requirements for this standard integration.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @sapmec,
We'll need a feature request to support v4.
That being said, kindly PM me the serial number of the NAS for escalation.
Alternatively, you may post it here on the Ideas Exchange Board:
https://community.netgear.com/t5/Idea-Exchange-For-Business/idb-p/idea-exchange-for-business
JeraldM
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm assuming this effects all ReadyNAS since it's in the firmware so I have started to look into replacements. I really like my little beast and hate to give up the ship but I really need a low cost S3 backup with multiple copies.
I'm out of warranty so I don't think I can open a ticket. Has anyone else with support opened a ticket?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm out of warranty, too, but Netgear appears to have opened a courtesy case for me, 45615391:
My name is Rene and I will be working with your case. We may need to open a feature request to support v4 signature on Amazon S3. But it will be best to open it using our website below so you can interact directly to our Engineers.
@Timtech wrote:I'm assuming this effects all ReadyNAS since it's in the firmware so I have started to look into replacements. I really like my little beast and hate to give up the ship but I really need a low cost S3 backup with multiple copies.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ended up going with a Synology. I didn't see any extra performance but at least Backblaze is working again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI...for what's it's worth I switched to using ChronoSync app locally on server that does a sync with target Backblaze service.
