- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pro 6 running ReadyNAS OS 6.10.8 with RAID 6. Unable to access any of my shares. Web indicates "No volumes exist. NETGEAR recommends that you create a volume before configuring other settings. Navigate to System -> Volumes page to create a volume."
From the Admin page, error shows:
"Remove inactive volumes to use the disk. Disk 1,2,3,4,5,6"
Admin System Volumes page showing all 6 bays as red
"Volume is inactive or dead".
How can I recover my volume? What files do I need to attach for troubleshooting? I've downloaded the logs zip file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
Can you download the full logs and send it to us via PM? You can also email readynassupport@netgear.com
We may need to check if the array can still be mounted or if it will need data recovery.
Note: Data recovery charges may apply.
HTH
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Marc,
I just sent the log file via email. The PM option wouldn't allow me to attach the log file.
Thanks,
Vijay
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the heads up. Just PM'd the link to Marc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What steps can I take to troubleshoot?
So far, I've run a disk test which indicated:
Disk test failed in channel 3.
I powered off the unit and replaced disk 3.
Web interface still shows my volume as dead or inactive and still shows disks 1,2,4,5,6 in red and still tells me that I need to remove inactive volumes.
The device was configured with RAID 6, so I'm confused that it is not trying to rebuild the volume at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vaprasad wrote:
Tech support said the device is old and no longer supported.
Not only that, they never supported OS-6 on legacy NAS like the Pro-6.
It sounds like you have no backup of your data - is that correct?
Did the mods find anything in the log zip?
Sometimes the volume gets out-of-sync.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No backups. I got lazy about getting a replacement backup drive as utilization increased.
Never heard back from the mods on the what could be found.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apologies for the delayed response it seems that my PM did not reach you properly.
This issue happened after the upgrade to 6.10.8 and I only found BTRFS errors that affected the mounting of your volume. If you have backup, you can opt to restore the volume by re-initializing the NAS and restore data from backup. However, this is not the case so I think a Data recovery service would be needed. I will send another PM as well.
Thanks @StephenB for the mention
HTH
