× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Volume not expanding - with encryption
chsu83
Luminary
Don't not the exact Pro 6 Model..
I've got a Pro6 with
2x 2TB and 2x 3TB
All worked fine except the XRAID2 isn't working.. at least not how expected.
I've installed ReadyNAS OS6 with factory reset.
Deleted the volume and recreated it.
Because the default Data-XRAID volume isn't encrypted.
So marking all four disks. Create Volume Raid 5 with encryption. And activate XRAID.
Tested it on VM Appliance (without encryption) and it worked.
First it created a "normal Raid 5" and after that it took the free place from the 3TB disk and created a raid 1.. at least roughly it seems so. And its also what I expect.
But now on the Pro 6 it does not expand further than 4x 2 TB in Raid5.
Is there something to nudge the expand process? Or does it simply not work with encrypted volume. (Because all other tests  with XRAID worked fine and i got somewhat around 6.3 TBs.)
Model: RNDP6310-200|ReadyNAS® Pro 6
Message 1 of 9
Accepted Solutions
jak0lantash
Mentor
Betreff: ReadyNAS Volume not expanding - with encryption
md1 is the swap volume, so no need to touch that.
If the volume is encrypted, X-RAID won't be able to create sub RAID arrays on unused disk capacity in case of mixed capacity HDDs. It's just not compatible.
This is why the logs say "
Skipping X-RAID auto-expansion on encrypted pool data
Your solutions: use disks of the same capacity, or create separate encrypted volumes, or don't use volume encryption.
Message 6 of 9
All Replies
chsu83
Luminary
fdisk -l /dev/sda
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 4AB6C267-7EF1-410C-9DB1-746EFAC1141F
Device       Start        End    Sectors  Size Type
/dev/sda1       64    8388671    8388608    4G Linux RAID
/dev/sda2  8388672    9437247    1048576  512M Linux RAID
/dev/sda3  9437248 3907029119 3897591872  1.8T Linux RAID
fdisk -l /dev/sdb
Disk /dev/sdb: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: gpt
Disk identifier: 14C08FED-6110-48ED-9CB6-E891D3A1E6CC
/dev/sdb1       64    8388671    8388608    4G Linux RAID
/dev/sdb2  8388672    9437247    1048576  512M Linux RAID
/dev/sdb3  9437248 3907029119 3897591872  1.8T Linux RAID
fdisk -l /dev/sdc
Disk /dev/sdc: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 467D1AFA-EEC9-4A6A-BED6-7312DFA34629
/dev/sdc1       64    8388671    8388608    4G Linux RAID
/dev/sdc2  8388672    9437247    1048576  512M Linux RAID
/dev/sdc3  9437248 3907029119 3897591872  1.8T Linux RAID
fdisk -l /dev/sdd
Disk /dev/sdd: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors
Disklabel type: gpt
Disk identifier: 0A183F38-CFFF-486A-AA02-81EA4A0D7EC4
/dev/sdd1       64    8388671    8388608    4G Linux RAID
/dev/sdd2  8388672    9437247    1048576  512M Linux RAID
/dev/sdd3  9437248 3907029119 3897591872  1.8T Linux RAID
fdisk -l /dev/sdb
Disklabel type: gpt
Message 2 of 9
chsu83
Luminary
puh.. it seems like theres something over from the raid6 test :S
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
      5845994496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
      [>....................]  resync =  0.5% (10276820/1948664832) finish=291.4min speed=110830K/sec
md1 : active raid6 sda2[0] sdc2[3] sdd2[2] sdb2[1]
      1046528 blocks super 1.2 level 6, 512k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sda1[0] sdc1[2] sdd1[3] sdb1[1]
      4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
        Version : 1.2
  Creation Time : Tue Mar 28 23:30:15 2017
     Raid Level : raid1
     Array Size : 4190208 (4.00 GiB 4.29 GB)
  Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
   Raid Devices : 4
  Total Devices : 4
    Persistence : Superblock is persistent
    Update Time : Wed Mar 29 21:33:52 2017
          State : clean
 Active Devices : 4
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 0
           Name : 33eb049b:0  (local to host 33eb049b)
           UUID : 73f582d4:eb212081:661a269e:0369cfed
         Events : 238
    Number   Major   Minor   RaidDevice State
       0       8        1        0      active sync   /dev/sda1
       1       8       17        1      active sync   /dev/sdb1
       3       8       49        2      active sync   /dev/sdd1
       2       8       33        3      active sync   /dev/sdc1
/dev/md/1:
        Version : 1.2
  Creation Time : Wed Mar 29 00:07:57 2017
     Raid Level : raid6
     Array Size : 1046528 (1022.00 MiB 1071.64 MB)
  Used Dev Size : 523264 (511.00 MiB 535.82 MB)
   Raid Devices : 4
  Total Devices : 4
    Update Time : Wed Mar 29 00:29:12 2017
          State : clean
 Active Devices : 4
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 512K
           Name : 33eb049b:1  (local to host 33eb049b)
           UUID : 8af43a31:0aabdd5a:7cbd7294:fc716ca5
         Events : 20
       0       8        2        0      active sync   /dev/sda2
       1       8       18        1      active sync   /dev/sdb2
       2       8       50        2      active sync   /dev/sdd2
       3       8       34        3      active sync   /dev/sdc2
/dev/md/data-0:
        Version : 1.2
  Creation Time : Wed Mar 29 07:48:01 2017
     Raid Level : raid5
     Array Size : 5845994496 (5575.17 GiB 5986.30 GB)
  Used Dev Size : 1948664832 (1858.39 GiB 1995.43 GB)
   Raid Devices : 4
  Total Devices : 4
    Update Time : Wed Mar 29 21:32:46 2017
          State : clean, resyncing
 Active Devices : 4
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 64K
  Resync Status : 0% complete
           Name : 33eb049b:data-0  (local to host 33eb049b)
           UUID : b8e3be8c:5c3f556b:90d6189c:4a27892f
         Events : 134
       0       8        3        0      active sync   /dev/sda3
       1       8       19        1      active sync   /dev/sdb3
       2       8       35        2      active sync   /dev/sdc3
       3       8       51        3      active sync   /dev/sdd3
Message 3 of 9
chsu83
Luminary
Have done:
 mdadm --grow /dev/md/1 --level=raid5
mdadm --grow /dev/md/1 --raid-devices=4
 rebooted
but have
in LOG
Message 4 of 9
chsu83
Luminary
Message 5 of 9
jak0lantash
Mentor
Message 6 of 9
chsu83
Luminary
thank you for that.. good to know.
yep.. the swap I only touched because I thougt if something is checking raid level of different raids.. and only if all ar good and in same way configured then the expansion starts.. thats why I tried to make them similiar.
The statement, I've seen later 🙂
Message 7 of 9
chsu83
Luminary
So then.. cool feature.. personally I think its a cool implementation of it. Would perhaps be great for some situation, that there is a mini webservice to submit the key in the boot process without a key. Unfortunately this situation I couldn't thest via the VM, because I didn't now how to propagate the USB Stick.
Perhaps some time the possibility will come use XRAID with uneven disks and encryption. Or enabling/disabling encryption after creation of the volume..
*hoping*
Thanks to all of you, made the OS6 possible on legacy devices.
I'll have to think to destroy the volume, or buy new Harddisks.. :S - bad situation, if you got enough place with the cool XRAID 🙂
Message 8 of 9
jak0lantash
Mentor
If you wish to suggest a new feature, you should post it in the "Idea" section. That way people can vote for it if they want to.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 7618 views
  • 0 kudos
  • 2 in conversation
Announcements
