richai
May 17, 2018Aspirant
GS724T v?
I have a customer with 4 gs724t smart switches. They recently had a audit (they are afinancial institution), and the audit recommended they thurn off telnet. On the v4 of this switch the GUI interface has the option to turn telnet on and off by going to maintenance->Troubleshooting->Remote Diagnostics. On their switch the GUI in the same place does not have the Remote Diagnostics option. I am guessing they are v3 or earlier. Is there a firmware upgrade for this or is there a different way to turn off telnet? There is no console port on these switches that I can see.
Hi Richai,
Thanks for your confirmation.
Please upgrade to 6.3.1.19 if switches are GS724Tv4.
The new firmware enhanced the feature just you want(Remote Diagnostics)
Please reference following guide to upgrade:
How to upgrade GS724Tv4 to 6.3.1.19.
May the solution help you.:smileyhappy:
- santoshsAspirant
I have Netgear XS712T and it does not have remote diagnostic option to disable.
I want to disable Telnet on this Switch due as it shows port 60000/Telnet open.
I am using 6.1.0.33 Firmware
Is there any other way to disable the Remote Diagnostic/Telnet
- RennaDNETGEAR Moderator
Hi santoshs,
Welcome to the NETGEAR Community! đ
Since there is no Remote Diagnostics in GUI this means what you have is XS712Tv1. To disable Telnet access you can instead run the command below to set the number of Telnet connections to "0" users:
(XS712T) >enable(XS712T) #telnetcon maxsessions 0
RennaD
NETGEAR Team- santoshsAspirant
Hi Reena,
There is no console port on XS712T.
How to access console on XS712T?Thanks for your help
- richaiAspirant
I am not sure how to reply to the response to my question but, the switches are V4 and are out of date on the firmware. Is updating the firmware the same as other hardware, download on PC and push to switch, ot is there a special way to do it? Thanks for your quick response on the initial question.
- DanielZhangNETGEAR Expert
Hi Richai,
- richaiAspirantThe fimware update solved the problem. Thank you.
Hi richai,
Welcome to NETGEAR communityïŒ:smileyhappy:
Could you please confirm the firmware version on the GS724T which don't have option to disable remote Remote Diagnostics.
If the firmware is 6.3.x.x and the switch is GS724Tv4.
Please upgrade to 6.3.1.19 since we add this option on 6.3.1.16 or later release.
If the firmware version is 5.4.x.x and the switch is GS724Tv3.
We don't have GUI option to control it.
But we have another way to disable Telnet and i can send PM to you about it.
Let me know if your switches are GS724Tv3.
Thanks,
Daniel.
