deroliver's avatar
Jun 03, 2019
NETGEAR Insight VPN macOS 10.14.5
I just installed my new BR500 and added a new vpn user. Unfortunately I cannot get the InsightVPNClient to run on my macbook pro running macos 10.14.5. It just crashes everytime I open the app. How can I fix this?
  • MrJoshW's avatar
    MrJoshW
    NETGEAR Employee Retired
    Hello,
    I am using OSX 10.14.2 with the latest Insight VPN client and I can connect with any issues. What version of the VPN client are you currently using? Do you have any other VPN clients installed?
      • MrJoshW's avatar
        MrJoshW
        Tested this on 10.14.5 just now and able to connect to my VPN group without any issues.
  • I am having the same issue of it crashing on startup.  I also have MBP 2016 with Mojave 10.14
    My Error is also the same as posters..
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
    Exception Note: EXC_CORPSE_NOTIFY
    Works fine on Windows 10 machines, have not tested on any other OSX machines.  Bought two of these BR500 specifically so I could use VPN to remote desktop on all the PC workstations I manage.  Completely useless without working on my MBP
    • deroliver's avatar
      deroliver
      Tutor
      I figured that the insight vpn app is not crashing when my my macbook is connected to an external monitor and the internal display is turned off. I've already gave this information to the netgear support but unfortunately so far there still is no bugfix in sight - so the insight vpn client ist useless to me. :-(
      • MrJoshW's avatar
        MrJoshW
        Hello,
        You are correct, engineering believes the issue is due to the resolution being used on some of the MAC models. Currently they are working on a possible fix and I am working with them to determine a possible release date to address this issue.
    • DaneA's avatar
      DaneA
      deroliver / Pdabz / wowpeter / jkupe / PurelyAndy / OlivierBart / ModoL / Mluce6 / EKKO_Coleman,
      In relation to the problems stated on this thread, several different complaints across a variety of Apple hardware platforms are being investigated and a fix is currently being worked on.
      It would be best that you subscribe to the community thread here and wait for updates.
      DaneA
      NETGEAR Community Team
      • RobAmour's avatar
        RobAmour
        Apprentice
        But nobody's posting any useful update in there, so what's the point?  Nobody has responded to the issues raised about Netgear's capability, and testing practices.  Plain and simple, you don't understand the Mac platform.
  • Exactly the same problem, nobody find a solution ? I buy it juste for my Mac and i can't use it ....
  • I am having the same issue. If it’s just a resolution issues, you would think it could’ve been fixed by now. It makes it useless on all my company’s Mac devices... the whole purpose we got this VPN in the first place.
    I planned to purchase more, but I’m extremely disappointed that it doesn’t work on any of our Mac’s, especially after all these months. I guess I will have to look at other products, if this issue doesn’t get fixed soon.
  • A new client InsightVPN 1.1.0.21 can be download, could you tell me if it resolve the probleme ? Thx
      deroliver
      Tutor
      Unfortunately I cannot install the updated app. The download seems to be corrupted/damaged. It has only 524 kb. The old download pkg had 5 mb.
    • MrJoshW's avatar
      MrJoshW
      The latest release does not include the issue of the client crashing on MacOS versions/builds. Due to the nature of the issue we are trying to pin point further on the issue and how it is being caused. Engineering is working on a test debug build for testing in the coming weeks that will have available to public testing. Once I have the build from engineering build for public testing I can send the build to available canidates.
      • jkupe's avatar
        jkupe
        Any updates on this? We just purchased the BR500 so all our engineers could connect from there Macbook Pros to the VPN and the client crashes on all of their machines.
  • MrJoshW's avatar
    MrJoshW
    GOOD NEWS EVERYONE! I have obtained the debug build. If anyone who is experiencing the crashing and issue would like to test the debug build please send me a private message and please provide feedback.
    • OlivierBart's avatar
      OlivierBart
      Great !! I can't test for the moment but i'm interesting to know the result. Thx.
      • broce381's avatar
        broce381
        As you are asking for a reliable VPN for watching Apple TV then I would recommend VyprVPN. It is known as a veteran provider that has compressed the geographic limitations on content from Netflix, Hulu, and other famous streaming channels. It’s also an excellent option for users who live in China and who want to bypass the Great Firewall. Go for https://vpn.review/apple-tv-vpn-setup/ to find out more about VPN set up. This VPN is not only supple, it’s also a strong performer, and has high-end encryption and fast download speeds.
        The corporation functions VyprDNS, its own private and encrypted DNS service, which helps in unblocking and keeping your browsing habits secure. It has been tested that it works perfectly fine for Apple TV. To set it up on DNS Proxy go for the Main menu, tap Settings > Network. Detect your present network and choose Configure DNS > Manual. Now add the DNS address from MediaStreamer or whatsoever DNS provider you’re utilizing. It should be a cord of numbers and decimals, pick the option says Done before resuming Apple TV.
      • MrJoshW's avatar
        MrJoshW
        Engineering believes the issue is with MacOS and webview. They are currently working on a test build with a webview fix. Once I hear feedback from them I will report any updates.
  • Is there already a update that works with macOS 10.15.4 Catalina ?
ProSupport for Business
