bettley_smith
Jun 28, 2011Aspirant
Remote Upload
Am I going wrong?, I can use the remote email to upload pictures and they appear, when I try the FTP upload, i can see then in the upload folder but they do not transfer to my Readynas Album.
- viperhansaVirtuosoI have problems with ftp upload, it says password is wrong.
I connect and can see in log that it passes the user and moves on to the pw.
Ideas?? - viperhansaVirtuoso
viperhansa wrote: I have problems with ftp upload, it says password is wrong.
Ideas??
This problem solved...
Seems to be some issues with accountname...
Next question, i now can upload trough ftp, i see the image in ftp browser on ftp.readynas....
How long will it take before it lands on my NAS? - yoh-dahGuide
viperhansa wrote: viperhansa wrote: I have problems with ftp upload, it says password is wrong.
Ideas??
Let me know if you don't see anything after 10 minutes. - viperhansaVirtuoso
yoh-dah wrote: viperhansa wrote: viperhansa wrote: I have problems with ftp upload, it says password is wrong.
Ideas??
Several hours has passed, no photos yet. - bettley_smithAspirantJust moved to version 1.0.2, now get some problems listed and when i diagnose get this:
OK: All connection tests from ReadyNAS Photos II to UPnP Router and photos.readynas.com site are passed.
OK: Hostname BettleySmith is available.
Error: Fail to access Photos II (http://78.149.xxx.xxx:8086) from internet. (error=-1).
OK: Successfully found your public IP (78.149.xxx.xxx).
(xxx) to hide identity
What does this mean? - viperhansaVirtuoso
bettley-smith wrote: Just moved to version 1.0.2, now get some problems listed and when i diagnose get this:
Same here after update to 1.0.2.
1.0.1 worked good, except ftp uploads. - Darth_VaderNETGEAR Employee Retired
viperhansa wrote: bettley-smith wrote: Just moved to version 1.0.2, now get some problems listed and when i diagnose get this:
Can you check if your port number has been changed? No longer using 8086?
Thanks - viperhansaVirtuoso
Darth Vader wrote: viperhansa wrote: bettley-smith wrote: Just moved to version 1.0.2, now get some problems listed and when i diagnose get this:
Thanks
port number not changed.... still same.. - viperhansaVirtuosoAny soulotion to the ftp upload not working?
its a bit irritating when my photos get stuck on readynas server..
Why dont make a function to upload directly?
Or a app to send straight to my readynas?
Regards
// Hans - shtijnAspirantHow did you solved the problem with "Fail to access Photos II from internet. (error=-1).' ?
Because I'm having the same problem...
Thanks
