Automan's avatar
Automan
Apprentice
Dec 17, 2014
6.2.0 Power Timer Schedule Not Cleared During Factory Reset
Sorry, if this has already been reported but it would seem if you perform a "Factory Reset" and you had shut down and start up times set that these are not cleared and thus if you power down the NAS it will turn itself back on at the time you had set before the factory reset.
To fix I just enabled power timer option and then cleared it.
It would be interesting to see if this issue effects the spin down and wake on lan options also?
ProSupport for Business
