kingbadger
May 27, 2011Aspirant
ReadyNASRemoteUpgrade.exe disables network adapter
I am just configuring a new ReadyNas and had set up ReadyNASRemote when it informed me I had to upgrade. I just downloaded and ran the upgrade but it modifies and disables the network adapter and I have to unistall it to get my network & the internet back. Not good Netgear...please fix this ASAP as it will not allow me to run the regular download without upgrading.
- kingbadgerAspirantmdgm, thanks -
Yes, I can check for firmware updates "The system is already running the latest firmware. Click Perform System Update if you wish to proceed with the update anyway." (so I see your point - to do this the ReadyNas must be getting to the internet)
But I cant configure the add on - I get the message "ReadyNAS Remote could not connect to the ReadyNAS server, please check your internet connection and DNS settings. If the ReadyNAS is behind an HTTP proxy, please make sure you have entered correct proxy server settings" when I try to "Manage ReadyNas Remote".
But I am not using a proxy server. My internet connection is straigtforward DHCP - dynamic with DNS provided automatically by my ISP
Radiator is 4.1.7, ReadyNas Remote is 1.6.5.16 (both are latest updates) the add on version on the NAS is 1.0.9.51 - mdgm-ntgrNETGEAR Employee RetiredUnder Services > Installed Addons you should see the version of ReadyNAS Remote installed. I believe the latest is 1.0.9.51.
You can download the latest version here: https://remote.readynas.com/download.html
You want the Sparc (not x86) version of the add-on. Installation is via System > Update > Local. - kingbadgerAspirantSorry, I just spotted it - I already have this version. I did try the X86 version but it found a checksum error and would not install, so I am on the latest Sparc version.
- mdgm-ntgrNETGEAR Employee RetiredCould you try installing the latest Sparc add-on over the top of itself?
- kingbadgerAspirantwill do
- kingbadgerAspirantI just did it - I downloaded it again using the link you provided, installed it sucessfully over the top of the previous on the NAS but still see the same message when I try to "Manage". It gees through "getting Version" then "Checking registration" then a dialog with "ReadyNAS Remote could not connect to the ReadyNAS server, please check your internet connection and DNS settings. If the ReadyNAS is behind an HTTP proxy, please make sure you have entered correct proxy server settings" comes up
Puzzling. - mdgm-ntgrNETGEAR Employee RetiredIf you look under Network > Global Settings are the Default Gateway and DNS Settings you see the NAS has picked up from your router correct?
If you download your logs (Status > Logs > Download all logs), extract the zip contents and open network_settings.log do you see a LeafNets adapter with an ip address 5.XXX.XXX.XXX? - kingbadgerAspirantYes, default gateway is showing as 192.168.2.1, as is DNS 1 (DNS 2 and 3 are blank). This is the correct IP for my router.
But no leafnets adapter - with any IP address. Below I pasted the log, but in Control panel>Network and Internet>Network Connections I can see the adapter. It is "enabled" but its status says "No network access".
eth0 Link encap:Ethernet
inet addr:192.168.2.3 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:7936 Metric:1
RX packets:10953062 errors:7 dropped:7 overruns:0 frame:0
TX packets:4034786 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4152413659 (3.8 GiB) TX bytes:4092504474 (3.8 GiB)
Interrupt:41
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2357957 errors:0 dropped:0 overruns:0 frame:0
TX packets:2357957 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:265082730 (252.8 MiB) TX bytes:265082730 (252.8 MiB)
JUMBO_FRAMES_eth0=1
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION - mdgm-ntgrNETGEAR Employee RetiredI would not post the HWaddr (i.e. MAC address of the ethernet NIC as this uniquely identifies your NAS).
Have you tried rebooting your NAS? - kingbadgerAspirantThanks for warning me about the MAC address...duly edited.
Same problem but progress indicator seemed to get much farther - ie it was Getting Version then checking registration before the dialog pops up
It then pops up the advanced screen (for me to enter my proxy settings, if I had any) Dont suppose a device ID would help?
