alt1's avatar
alt1
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all,
Here's the situation...
Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7
Installed 2 x WD HDD's 1TB each WD10EZRX
First boot-up everything went fine and was using the NAS last night.
when I came in this morning the NAS had crashed. I had to pull the power plug to reboot. This is where the fun started.
I have tried everything. Tried WD Lifeguard Write Zeros, tried deleting partition/creating/formatting/not-formatting. Tried diskpart 'clean' - at this stage i'm out of ideas
The HDD's will run through Factory Reset no problem and go as far as choosing which RAID set-up I want in RAIDar. After this stage the errors start, some of which:
Raid Creation Failed
I have tried different RAID configurations, tried 1 HDD at a time etc. I am totally out of ideas.
The strange thing is that when I install an old Seagate 160GB HDD, it works flawlessly! (Didn't have time to check if it crashes after a few hours)
Are these HDD's simply not compatible with this NAS? Seems strange, because it worked for a few hours last night
ProSupport for Business
