plingis30000
Sep 05, 2011Aspirant
Rsync not completing - just .xls-files is problem...
Hi!
I am trying to use Rsync to backup the NV+ to a USB-drive. For some reason there seems to be problem by backing up .xls-files. I get these type of messages in the log:
rsync: set_acl: sys_acl_set_file(dokument/MAGNUS/FRITID/linda-magnus-ekonomi/hus/månadsvis överföringar/Fastighets-kostnader2010.xls, ACL_TYPE_ACCESS): Operation not supported (45)
rsync: set_acl: sys_acl_set_file(dokument/MAGNUS/FRITID/linda-magnus-ekonomi/hus/månadsvis överföringar/Fastighets-kostnader2011.xls, ACL_TYPE_ACCESS): Operation not supported (45)
rsync: set_acl: sys_acl_set_file(dokument/MAGNUS/FRITID/ppm/valda-fonder-ändring-2010-04-28.xls, ACL_TYPE_ACCESS): Operation not supported (45)
I have not come to "the end" of the backup job because of this... Does anyone know why I´m getting this messages and how can I resolve them?
Best,
Magnus
Best,
Magnus
- mjw1AspirantYes. All you are doing is to save a UserMapping file in your usb drive so that the new ntfs driver software knows how to map between Linux and windows users.
- plingis30000Aspirant
mjw wrote: Yes. All you are doing is to save a UserMapping file in your usb drive so that the new ntfs driver software knows how to map between Linux and windows users.
Ok, thank you. Do you think this problem:
viewtopic.php?f=4&t=57164&p=322707#p322707
has to do with that Mapping file too?
Best,
Magnus - plingis30000Aspirant
Hi!
I generated the ".NTFS-3G" directory and placed the "code" in the file "UserMapping" and it was still problem to go all the way to finish the job.. A bit up in the logs there were some ".doc-files" that has to been removed/renamed and after that the job was finished. I was very happy... It seems that "Microsoft Office"-files causing this problem...?
How to go futher on do you think?
Best,
Magnus - mjw1AspirantSo, I'm a bit confused - does you backup now finish 100% successfully or are there errors in the logs?
If there are still errors, please can you post any error or warning messages you saw in the log? - mjw1AspirantAlso, please ssh into your readynas and run this command:
ntfs-3g -help
My readynas prints out the following:
tera:~# ntfs-3g -help
ntfs-3g 2010.10.2AR.1 integrated FUSE 28 - Third Generation NTFS Driver
Configuration type 7, XATTRS are on, POSIX ACLS are on
Copyright (C) 2005-2007 Yura Pakhuchiy
Copyright (C) 2006-2009 Szabolcs Szakacsits
Copyright (C) 2007-2010 Jean-Pierre Andre
Copyright (C) 2009 Erik Larsson
Usage: ntfs-3g [-o option[,...]] <device|image_file> <mount_point>
Options: ro (read-only mount), remove_hiberfile, uid=, gid=,
umask=, fmask=, dmask=, streams_interface=.
Please see the details in the manual (type: man ntfs-3g).
Example: ntfs-3g /dev/sda1 /mnt/windows
Ntfs-3g news, support and information: http://ntfs-3g.org - plingis30000Aspirant
mjw wrote: So, I'm a bit confused - does you backup now finish 100% successfully or are there errors in the logs?
I had errors in the logs but deleted them... I tried to regenerate an error by moving the .NTFS-3G directory and saved a word-file on the NAS and then reboot the NAS but now it goes allt the way and finished by 100 %. When there are no errors in the log I think its hard to start searching?
But there are som major problems:
viewtopic.php?f=124&t=57211
and I think that all these stuff has to do with each other.
Best,
Magnus - mjw1AspirantMy suggestion would be to put the UserMapping file back to the correct location, clear the backup logs, reboot, then run a completely fresh backup but use a different destination folder on your USB drive. That way, all your files will be copied once. Then post any errors that appear in the log after this backup completes. Or if there are no errors, then even better - perhaps your problem is solved.
Also I should ask - do you have more than one user that has saved the same MS Office / excel file? The reason I ask is that I have found that when ms office files are saved first by one user then a second time by a different user, then an ACL is saved. You can actually see the ACL information for a file using the Linux getfacl command. Anyway, on the readynas backup jobs run using either the cp -p command or the rsync -Ava command. Both commands attempt to copy (preserve) file attributes such as ACLs. This always caused errors when copying to a ntfs USB drive in prior versions of Raidiator (<= 4.1.6) because the ntfs driver did not support acls. This should now be fine in 4.1.8 as long as netgear has enabled acl functionality (I'd be surprised if it's not enabled). You probably just need a UserMapping file for this to all start working. Also you should notice that without a UserMapping file all files in your backup end up losing file ownership info and show up as root/root if you do ls -l; but once you create the appropriate UserMapping file all your file ownership and your ACLs will be correctly backed up as well as the content of each file. - plingis30000AspirantOk, Thanks a lot for your answer!
Best,
Magnus
