Retired_Member's avatar
Retired_Member
Mar 05, 2012
Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable...
My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wifi with one of them
I came across this item:
http://www.newegg.ca/Product/Product.as ... 6833122373
I'm wondering if it would work with the Readynas. I picked this one because it is made by Netgear so there shouldnt be compatibility issues... Also, it is powered by USB so i wouldn't need an external power adapter
Thanks for help
ProSupport for Business
