- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M6 Pro MR6500 Dropping internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use it for wifi. I only have the nighthawk plugged directly into my computer via ethernet. I tried a new ethernet cable and it didn't change anything. I brought it to the ATT store and they switched it to ethernet offloading which made it worse - there was no connection at all. Then they gave me a new sim card, this didn't work as well. I spoke with Netgear support for over an hour and worked through all their troubleshooting to no avail. They said they'd have their engineer call me - they didn't - this was several weeks ago. My case ID# is MS48C3363 if that helps. I previously used an older model that worked well but it finally died which is what prompted the replacement and I've had nothing but issues since. I've noticed that the disconnection occurs during downloads or during online gaming. The speed will gradually slow down then drop completely. I've also had several instances where the internet will drop and reappear repeatedly every few seconds. Restarting the router has been the fix but sometimes it only lasts 5 minutes before having to repeat this. My firmware is up to date. My firmware is up to date and it is: NTGX65_10.04.22.01. Any help would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M6 Pro MR6500 Dropping internet
Hello,
I faced the same problem. Have you found any solution?
FW: NTGX65_10.04.16.00
Best Regards,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for replying late. Could you please capture a model.json file and send email to me @jopeng@netgear.com?
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
We would like to get more info from you.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply, I've chalked this up to a lost cause and have settled that this M6 is just a $500 paperweight now. I've discontinued my use of the product and replaced it with an older MR1100 I got off amazon. Just had to slot the sim card and get an APN for it to work. Speed is the same as the M6 when it would stay connected, now I just don't have to worry about the random disconnects. MR1100 is just a more reliable device.
To anyone else here with the same problem looking for answers just replace device with an older model. The M6 is an unfinished product that they're selling for top dollar; I spent months and an exhaustive amount of effort trying to find a fix when there wasn't one. Save yourself the time and headache - the MR1100 works just as well without the disconnects.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having exactly the same problem with a MR6150, it may be the firmware is buggy and a later version in the future will correct this problem. It's unacceptable to me and at the cost I paid for this premium hotspot I will probably return it and continue using the old one I was going to replace. I opened a case with support and may try one more time to get some answers, but right now it looks like an RMA. It's a shame because when it does work I really like the performance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please also detail your use case and device setup, etc.
Thanks
John
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello John, I emailed the information you requested. Hope you can help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I received my MR6500-1TLAUS today and set it up. Internet connects for few minutes then drops out.
I I've been using a MR5100 in the same location, no issues....
Does the MR6500-1TLAUS have bugs? Should I return it to telstra?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Telstra is going to approve a new release soon. Please email me your device IMEI to jopeng@netgear.com and mention your community ID. I can set your device up to preview the coming maintenance release. It includes many feature enhancements and resolves data stability issues as you saw in the current release.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M6 Pro MR6110 Dropping internet
I'm having similar problems with an AT&T M6 (MR6110) less than 1 week old. I'm using it without battery and ethernet only (wifi off) to feed my router. After various lengths of time (1 hour, 8 hours, 2hours) it drops out - the internet connection is dropped. Unplugging it and restarting it usually fixes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send me the model.json file to me at jopeng@netgear.com with your community name.
- Logon to the webui (http://192.168.1.1 ) as an administrator. Log in to WebUI first
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the help (john peng). It sounds like AT&T hasn't rolled out the latest drivers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have sent you my json file
Thanks for your assistance
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm still in the AT&T 14 day return/replace, so I'm getting it swapped out to see if that helps any. Thanks for trying with AT&T. (it also has a 1 year warranty).
- Mark as New
- Bookmark
- Subscribe
- Permalink
My firmware was NTGX65_10.01.47.00, so at least you have a more updated version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
sbrady4 wrote- I'm still in the AT&T 14 day return/replace, so I'm getting it swapped out to see if that helps any. Thanks for trying with AT&T. (it also has a 1 year warranty).
Could you please report back on this thread whether swapping it out fixed your problem? I returned my mr6150 that was doing the same thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get a replacement unit or did you just get your money back and move on? Where did you get your MR6150 from originally?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
jt240z wrote- Did you get a replacement unit or did you just get your money back and move on? Where did you get your MR6150 from originally?
I bought it from Netgear, and returned it for a refund after all Netgear remote tech support troubleshooting was exhausted and the service drop issue could not be resolved. The unit probably had a hardware defect, maybe a failing modem because the issue got worse and worse as time went on. I may try and get a good one later, I really wanted it to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@gladu2 wrote: Could you please report back on this thread whether swapping it out fixed your problem? I returned my mr6150 that was doing the same thing.
So I Got the new 6110 replacement device. Set up (without battery and wired ethernet cable) and initially my PC was disconnecting from ethernet every 3 minutes. The Windows 10 network troubleshooter could fix it, and it'd work for 3 more minutes or so. It would say "The default gateway is not available". then it would fix it. I had set the M6 ethernet to 1000Mbps.
I called AT&T and they said try wifi only, maybe something with my PC. It did stay connected with wi-fi. Then I switched to (wired) 100Base-T and it stayed connected longer. So I'll continue testing. The device itself says it has been connected over 2 hours during all this loss of wired connection. I really need the wired connection to work. That was my whole point for buying that router. I want to use it with my own wired router as home network in an area with no phone or cable (and fixed wireless didn't have line of sight), but phone works great and fast where I'll put the hotspot. The first one did work great when it was working - 5G speed for a few hours before freeze up. I'm not at that location now, so can't test in final position until end of next week.
Also: This one came with firmware version NTGX65_10.04.22.00.
