Orbi WiFi 7 RBE973
Reply
Recycle bin on RN104
neonshades
Tutor
Please give me an easy answer.... and please only answer if you know (no guesses).
is there a tick box to enable the recycle bin on the RN104?
My ReadNas NV+ V2 has a tick box to enable the recycle bin but I cannot find it in the RN104 menu. Help....
Thanks,
Robert....
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 8
BrianL2
NETGEAR Employee Retired
Re: Recycle bin on RN104
Hi neonshades,
Welcome to the community!
The answer to your question can be found on this thread.
Kind regards,
BrianL
NETGEAR Community Team
Message 2 of 8
neonshades
Tutor
Hi BrianL,
Unable to follow your thread. Will not accept my login.
Nor will it send me a password update.
Robert....
Message 3 of 8
Guru
Must be a cut-and-paste error on Brian's part.
You could look here: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-...
and perhaps read through the posts after the highlighted thread as well.  The process will require some knowledge of linux.
Though I find Snapshots to be a good alternative.  With snapshots enabled, you can roll-back to older versions of the share, and if you right-click from windows on a file you can see/access previous versions.  If you right-click on the folder and access previous versions, you can select deleted files and restore them. It's not exactly the same as the recycle bin, but it is similar.
Message 4 of 8
BrianL2
Hi neonshades,
Sorry, I made a mistake with the link I used in my previous post (I already updated it). Anyway, StephenB already gave an introduction on how Snapshots work on the new OS 6 systems. Just let us know if you have further questions.
Kind regards,
BrianL
Message 5 of 8
neonshades
Tutor
Hi BrianL,
Thanks for the help but snapshot is not what I needed. Guess the simple answer is no, the recycle bin tick box has been removed from the RN104 operating system.
Shame really.
Robert....
Message 6 of 8
BrianL2
Hi neonshades,
I apologize if the said feature you are looking for is unavailable on the new OS 6 system. If you want this feature to be added again, I suggest that you post another thread on this board.
Kind regards,
BrianL
Message 7 of 8
davexyz
From the original post of JMehring 20 November 2013
putty and ssh required
1) create file addons.conf as below
\etc\frontview\samba\addons\addons.conf
I think you have to create the addons directory as well.
2) then edit addons.conf, I use vi, to include the shares that you wish to have Recycle Bin activated for (include the square brackets)
[name of your share 1]
vfs objects = recycle
recycle:repository = Recycle Bin
recycle:keeptree = yes
recycle:versions = no
[name of your share 2]
3) Save file. As you can see you can choose the name of the "bin" . leave putty window  open
4) to "activate"  go to frontview interface on the nas and the share window
 toggle a property of the share for example ftp on to off.  this reloads the config file to include addons.conf
5)then in putty window type:
testparm
this should list your shares and show the recycle:parameters for the shares defined
6) close putty
I did this and I was a complete linux/ssh novice.
If you  install/update firrmware on the nas check that this file exists, factory reset obviously wipes this file
It works for usb attached drives etc just use the drive name ie USB_HDD_1 etc
for very large >5Tb usb drives there is  also a bit of a fidddle required on some NAS' due to the adding of the addons.conf file to the "main config file. If it does not load then post and I can give pointers on how to correct.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4901 views
  • 0 kudos
  • 4 in conversation
Announcements
