orbi 770 series
101 TopicsNew - RBE771v2 / RBE770v2 Firmware Version 12.1.7.21 Released
Release Date: May 23, 2026 New Features and Enhancements: Initial Release Download Link: https://www.netgear.com/support/product/rbe772v2 Only for the 770v2 series. Not compatible with the v1 series. Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual. IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR771v2/RBS770v2: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. Recommend powering OFF the Orbi system for 1 minute then back ON with the RBR first then RBS after Update All completes. Give 5-10 minutes for system to fully come to ready. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: This sends a Factory Reset command to any and all connected RBS as well: Procedure for Factory Reset of RBE770 series systems use ERASE Button This article applies to: WiFi 7 (4) RBE770v2 RBE771v2 RBE772v2 RBE773v2 Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities33Views0likes0CommentsNew - RBE770 / RBE771 Firmware Version 10.5.20.10 Released
Release Date: January 28, 2026 Bug Fixes: Resolved security vulnerabilities Resolved P2 security vulnerabilities in accordance with Security Team requirements Implemented IPv6 automatic detection and configuration Download Link: https://www.netgear.com/support/product/rbe772/#download RELEASE NOTES links are not working on the download site. Made NG support aware of this. Hopefully fixed soon. Release not information is with in the .zip files for this version of FW. 1/30/2026: Links have been fixed. Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RBE771.aspx#docs IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR771/RBS770: Proceedure to Manually Firmware Update Orbi and Nighthawk Mesh systems I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. Recommend powering OFF the Orbi system for 1 minute then back ON with the RBR first then RBS after Update All completes. Give 5-10 minutes for system to fully come to ready. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: This sends a Factory Reset command to any and all connected RBS as well: Procedure for Factory Reset of RBE770 series systems use ERASE Button This article applies to: WiFi 7 (4) RBE770 RBE771 RBE772 RBE773 Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities747Views0likes0CommentsOrbi 770, ipv6, Gigaclear - works then drops
I'm trying to get my Orbi 770 to have a stable ipv6 connection with my ISP Gigaclear. Initially it works, then it doesn't. The Orbi 770 is running Firmware Version V10.5.20.10_2.2.51 My connection to Gigaclear is via a new DKT Comega ONT. I have a static IPv4 address from Gigaclear. On the Orbi web UI, I have these IPv6 settings: Internet Connection Type: Auto Config DHCP User Class: blank DHCP Domain Name: blank Router's IPv6 Address On WAN: Not Available Use These DNS Servers: Primary DNS 2606:4700:4700:0000:0000:0000:0000:1111 (Cloudflare 1.1.1.1) Secondary DNS 2620:00FE:0000:0000:0000:0000:0000:00FE (9.9.9.9) LAN Setup Router's IPv6 Address On LAN 2a06:61c0: etc etc IP Address Assignment: Auto Config Enable RIPng (off) Use This Interface ID: blank IPv6 Filtering: Secured My Windows 11 PC, connected via ethernet to one of the Orbi Satellites 1. Gets a proper IPv6 address 2. Scores 10/10 on https://test-ipv6.com/ My Samsung S25, connecting via wifi 7 or 6 or 5 1. Gets a proper IPv6 address 2. Scores 10/10 on https://test-ipv6.com/ Even my Linux VM scores 10/10. But then after some hours (more than 4 less than 24), the IPv6 fails and the https://test-ipv6.com/ scores become 0/10 on all devices. I've spoken to Gigaclear. The person on the phone was not aware of any special settings or issues. They are passing this to network engineers. Can this be fixed? I've tried: 1. Turning on / off everything 2. Changing Internet Connection Type: Auto Config DHCP User Class: blank to Internet Connection Type: DHCP DHCP User Class: 1 For a while it works, then it doesn't.57Views0likes3CommentsOrbi 773 versus 773v2?
I bought an Orbi 773 at BestBuy today. To prep, I downloaded the user manual and also the firmware in case the unit I bought isn't up to date (although I assume it will auto-update on initial setup, I still like to have the firmware files local). Noticed there is different firmware versions for the 773 and 773v2. What is the difference between the v1 and v2 models and how do I tell which one I have? On the bottom of the 771 router the model states just RBE771 so I assume it's the original v1 and not the v2? Is this noted anywhere else? Should I care? ... are there important hardware/firmware performance and stability differences in the v2 and therefore I should return the v1 and purchase a v2 straight from Netgear's site? I tried searching on this topic but didn't find anything. Would really appreciate some guidance. Thanks in advance!395Views0likes15CommentsWifi Drops my printer within minutes
I have a new Orbi 770 mesh. 50 plus devices running on the network but my brother printer HL-L2370DW constantly drops offline. I have updated all firmware on printer and orbi devices. I have rebooted the Orbi mesh and printer several times. I set up a static IP of 192.168.1.2 for the printer, which shows up on Orbi for a few minutes but as soon as I boot up my printer I have only minutes of use, then it drops off line. I have attached screen shot of the issue. Please help.187Views0likes13Comments771 mesh router and satellite - no seamless transitions
I have the 77X mesh router and satellites, and whenever I move from upstairs (where the main router is) to ground floor (satellite location), my phone ‘s wifi disconnects and takes a long time to reconnect (I often just forget the network and reconnect with password, otherwise it takes more than 5 mins). I have the latest firmware and this issue has existed for a long time and was hoping that latest firmware would fix it permanently, but so far no luck. I never had this issue with an older wifi 5 mesh from Orbi, but this wifi 7 mesh has been consistently VERY unreliable.193Views0likes6CommentsOrbi 770 (EU) region change
I have the Orbi 750 which I'm thinking about upgrading to a 3-pack of Orbi 770. As I will be using it both in Norway and part of the year in Canada, is it possible to change the region in the web gui on the EU-version of the 770 like I can with the Orbi 750?87Views0likes1CommentWeb site Accessibility...Orbi BE systems
Anyone noticing any issues with accessing visited web sites with a wireless or wired PC connecting to Orbi systems with newest FW version loaded? Looking for anything in particular that stands out with seeing any 404 Errors or ERR_CONNECTION_CLOSED in a browser. Seen across other browsers? http://printables.com maybe one site. Any other sites that is giving issues, please post the details and site URL. ISP DNS or custom DNS used. IPv6 enabled or disabled. ISP service hardware details as well. Thank you.208Views0likes9Comments
