daveke's avatar
daveke
Guide
Jan 17, 2013
Can't login to router via Genie
While I can login to my router (WNDR4500) via my browser (Chrome and IE9), I cannot login to Router Settings via Genie on my PC (Win7). I receive a message of "Login failed. The router response timed out." I get a similar response when I try to access the NetGear Genie app via my iPad (3rd gen.): "Action timed out. Please try again.". This was not always the case. I first noticed over a month ago when I could no longer access the Network Map via Genie on my iPad.
The router is otherwise working fine, but I would like to re-establish the functionality of NetGear Genie app on my iPad--any ideas? I've tried deleting the app and re-installing, but that has not worked. I thought this problem was solely on my iPad, but only recently discovered the inability to login via the Genie app on my PC as well.
  • DexterJB's avatar
    DexterJB
    Jan 09, 2017
    Hi jwilson484,
    Please try the following steps:
    1. Uninstall and re-install the Genie apps/programs from your devices.
    2. Reboot the router.
    3. If it is an option, you can try doing a factory reset on the router.
    Dexter
    Community Team
