justwondering01's avatar
Oct 13, 2015
Genie app won't connect to OpenDNS
I am trying to useGenie Parental controls and when I attempt to login to my OpenDNS I get the following error
"There was an error signing, in please make sure you're connected to the Internet and try again"
I am connected to the internet and I can open my account using the same email and password on the OpenDNS site but Genie will not connect.
I have a N600 Wireless Dual Band. Model DGND3700v2 running firmware V1.1.00.15_1.00.15NA
Any ideas?
  • Patentagosse's avatar
    Patentagosse
    Nov 02, 2016
    Got it to work! In the end, it looks like the router did not reset properly when it was shut down. So I unplugged it, then put the power switch to on/of 4 or 5 times (to discharge the capacitors), then plugged the power cord back in. Once fully booted, the Genie app was able to talk to the router on the first try. What is wierd is that in the last weeks, all other devices must have contuinued to work with the Genie app since Parental Control/by-pass account was still working fine...
    Weird one...
    Anyway, thanks for your help Dexter! And I hope this is of use to someone... :)
