FURRYe38's avatar
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test.
Seems like the HW NAT accelleration or Cut-Through that should be working on this router, isn't. This test is using the WAN port. I don't have any support for the SPF+ port.
XR700: v10, Windows 10x64
Running Speed Test...
BPS=381,173,408
0: 46,162,930 (369,303,440 bps)
1: 44,496,047 (355,968,376 bps)
2: 47,100,631 (376,805,048 bps)
3: 46,419,757 (371,358,056 bps)
4: 47,902,495 (383,219,960 bps)
5: 47,483,139 (379,865,112 bps)
6: 48,509,496 (388,075,968 bps)
7: 47,458,189 (379,665,512 bps)
8: 48,363,038 (386,904,304 bps)
9: 47,680,747 (381,445,976 bps)
10: 48,528,357 (388,226,856 bps)
11: 47,632,508 (381,060,064 bps)
12: 48,478,207 (387,825,656 bps)
13: 47,473,227 (379,785,816 bps)
14: 48,275,259 (386,202,072 bps)
15: 47,733,464 (381,867,712 bps)
16: 48,092,973 (384,743,784 bps)
17: 47,932,226 (383,457,808 bps)
18: 47,362,523 (378,900,184 bps)
19: 48,375,352 (387,002,816 bps)
XR700: v10, Windows 7
BPS=370,111,704
0: 44,791,390 (358,331,120 bps)
1: 44,476,968 (355,815,744 bps)
2: 44,770,552 (358,164,416 bps)
3: 46,073,590 (368,588,720 bps)
4: 45,812,470 (366,499,760 bps)
5: 45,489,110 (363,912,880 bps)
6: 46,676,541 (373,412,328 bps)
7: 46,873,684 (374,989,472 bps)
8: 45,990,023 (367,920,184 bps)
9: 47,038,243 (376,305,944 bps)
10: 46,390,556 (371,124,448 bps)
11: 46,761,893 (374,095,144 bps)
12: 46,330,190 (370,641,520 bps)
13: 46,808,975 (374,471,800 bps)
14: 46,297,395 (370,379,160 bps)
15: 46,644,519 (373,156,152 bps)
16: 46,267,153 (370,137,224 bps)
17: 46,920,449 (375,363,592 bps)
18: 46,876,910 (375,015,280 bps)
19: 46,515,924 (372,127,392 bps)
Loaded v14 beta, Windows 7, factory reset and setup from scratch, wifi disabled:
BPS=372,898,760
0: 46,459,875 (371,679,000 bps)
1: 46,512,486 (372,099,888 bps)
2: 47,031,920 (376,255,360 bps)
3: 46,212,546 (369,700,368 bps)
4: 46,866,362 (374,930,896 bps)
5: 46,458,028 (371,664,224 bps)
6: 46,832,136 (374,657,088 bps)
7: 46,135,983 (369,087,864 bps)
8: 46,692,523 (373,540,184 bps)
9: 46,193,505 (369,548,040 bps)
10: 47,229,294 (377,834,352 bps)
11: 46,099,476 (368,795,808 bps)
12: 47,013,490 (376,107,920 bps)
13: 46,064,165 (368,513,320 bps)
14: 47,087,509 (376,700,072 bps)
15: 46,921,037 (375,368,296 bps)
16: 45,983,186 (367,865,488 bps)
17: 46,753,098 (374,024,784 bps)
18: 46,342,874 (370,742,992 bps)
19: 47,203,540 (377,628,320 bps)
 This would not be acceptable for users on a 1Gb ISP plan with this expensive top of the line NG gaming router. :smileyfrustrated:
My XR450 sees 900Mbps +
BPS=949,067,544
0: 118,942,890 (951,543,120 bps)
1: 118,632,281 (949,058,248 bps)
2: 118,632,793 (949,062,344 bps)
3: 118,634,072 (949,072,576 bps)
4: 118,636,572 (949,092,576 bps)
5: 118,630,824 (949,046,592 bps)
6: 118,638,303 (949,106,424 bps)
7: 118,634,627 (949,077,016 bps)
8: 118,636,011 (949,088,088 bps)
9: 118,631,677 (949,053,416 bps)
10: 118,632,337 (949,058,696 bps)
11: 118,632,660 (949,061,280 bps)
12: 118,635,038 (949,080,304 bps)
13: 118,634,658 (949,077,264 bps)
14: 118,631,777 (949,054,216 bps)
15: 118,634,063 (949,072,504 bps)
16: 118,637,281 (949,098,248 bps)
17: 118,628,200 (949,025,600 bps)
18: 118,628,983 (949,031,864 bps)
19: 118,630,948 (949,047,584 bps)
  • Nice job FURRYe38!
    I report earlier this issue and I though I was the only who had this WAN Port not reaching the Gigabit speed on my XR700. Thank you for validating this problem with your WAN to LAN test!
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      How were the speed tests done? If you used other platforms did they report the same?
      Is PPPoE/VLAN/IPv6 being used?
      Netduma-Fraser
      NetDuma Partner
      As you are able to do that test would you be able to repeat it using iPerf? That is what we (Netduma) use to test in the office.
      • FURRYe38's avatar
        I would presume results would be the same. I've tested with this more simplified program with other routers to compare.
        Does NetDuma see same or similar speed results in there testing with the XR700?
        iPerf Results:
        [ ID] Interval Transfer Bandwidth
        [ 5] 0.00-1.00 sec 34.0 MBytes 285 Mbits/sec
        [ 5] 1.00-2.00 sec 36.0 MBytes 301 Mbits/sec
        [ 5] 2.00-3.01 sec 34.8 MBytes 291 Mbits/sec
        [ 5] 3.01-4.01 sec 36.5 MBytes 305 Mbits/sec
        [ 5] 4.01-5.01 sec 34.8 MBytes 291 Mbits/sec
        [ 5] 5.01-6.01 sec 28.1 MBytes 236 Mbits/sec
        [ 5] 6.01-7.01 sec 36.6 MBytes 307 Mbits/sec
        [ 5] 7.01-8.01 sec 28.8 MBytes 240 Mbits/sec
        [ 5] 8.01-9.02 sec 36.9 MBytes 308 Mbits/sec
        [ 5] 9.02-10.02 sec 26.9 MBytes 225 Mbits/sec
        [ 5] 10.02-11.02 sec 33.4 MBytes 279 Mbits/sec
        [ 5] 11.02-12.02 sec 34.6 MBytes 290 Mbits/sec
        [ 5] 12.02-13.03 sec 35.9 MBytes 300 Mbits/sec
        [ 5] 13.03-14.03 sec 34.8 MBytes 291 Mbits/sec
        [ 5] 14.03-15.06 sec 35.9 MBytes 292 Mbits/sec
        [ 5] 15.06-16.06 sec 35.1 MBytes 294 Mbits/sec
        [ 5] 16.06-17.11 sec 28.5 MBytes 229 Mbits/sec
        [ 5] 17.11-18.11 sec 35.4 MBytes 295 Mbits/sec
        [ 5] 18.11-19.12 sec 37.0 MBytes 309 Mbits/sec
        Sent
        [ 5] 0.00-20.00 sec 676 MBytes 283 Mbits/sec
        Received
        iperf Done.
        Done.
        Speed seems all over place. Still nothing much over 300Mbps
  • FURRYe38's avatar
    4 Parallel Streams set:
    [ 5] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
    [ 6] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
    [ 7] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
    [ 8] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
    [SUM] 0.00-1.20 sec 7.50 MBytes 52.5 Mbits/sec
    [ 5] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
    [ 6] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
    [ 7] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
    [ 8] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
    [SUM] 1.20-2.20 sec 7.50 MBytes 62.6 Mbits/sec
    [ 5] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
    [ 6] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
    [ 7] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
    [ 8] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
    [SUM] 2.20-3.22 sec 7.50 MBytes 61.9 Mbits/sec
    [ 5] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
    [ 6] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
    [ 7] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
    [ 8] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
    [SUM] 3.22-4.23 sec 7.50 MBytes 62.5 Mbits/sec
    [ 5] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
    [ 6] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
    [ 7] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
    [ 8] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
    [SUM] 4.23-5.23 sec 7.50 MBytes 62.5 Mbits/sec
    [ 5] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
    [ 6] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
    [ 7] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
    [ 8] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
    [SUM] 5.23-6.24 sec 7.50 MBytes 62.2 Mbits/sec
    [ 5] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
    [ 6] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
    [ 7] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
    [ 8] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
    [SUM] 6.24-7.27 sec 7.50 MBytes 61.5 Mbits/sec
    [ 5] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
    [ 6] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
    [ 7] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
    [ 8] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
    [SUM] 7.27-8.27 sec 7.50 MBytes 62.9 Mbits/sec
    [ 5] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
    [ 6] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
    [ 7] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
    [ 8] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
    [SUM] 8.27-9.28 sec 7.50 MBytes 62.3 Mbits/sec
    [ 5] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
    [ 6] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
    [ 7] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
    [ 8] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
    [SUM] 9.28-10.29 sec 7.50 MBytes 62.3 Mbits/sec
    [ 5] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
    [ 6] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
    [ 7] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
    [ 8] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
    [SUM] 10.29-11.46 sec 7.50 MBytes 53.7 Mbits/sec
    [ 5] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
    [ 6] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
    [ 7] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
    [ 8] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
    [SUM] 11.46-12.47 sec 7.50 MBytes 62.4 Mbits/sec
    [ 5] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
    [ 6] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
    [ 7] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
    [ 8] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
    [SUM] 12.47-13.47 sec 7.50 MBytes 62.4 Mbits/sec
    [ 5] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
    [ 6] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
    [ 7] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
    [ 8] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
    [SUM] 13.47-14.48 sec 7.50 MBytes 62.4 Mbits/sec
    [ 5] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
    [ 6] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
    [ 7] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
    [ 8] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
    [SUM] 14.48-15.50 sec 7.50 MBytes 61.8 Mbits/sec
    [ 5] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
    [ 6] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
    [ 7] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
    [ 8] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
    [SUM] 15.50-16.68 sec 7.50 MBytes 53.5 Mbits/sec
    [ 5] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
    [ 6] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
    [ 7] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
    [ 8] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
    [SUM] 16.68-17.85 sec 7.50 MBytes 53.6 Mbits/sec
    [ 5] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
    [ 6] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
    [ 7] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
    [ 8] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
    [SUM] 17.85-18.99 sec 7.50 MBytes 55.2 Mbits/sec
    [ 5] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
    [ 6] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
    [ 7] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
    [ 8] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
    [SUM] 18.99-20.07 sec 7.50 MBytes 58.5 Mbits/sec
    Sent
    [ 5] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
    Received
    Sent
    [ 6] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
    Received
    Sent
    [ 7] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
    Received
    Sent
    [ 8] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
    Received
    Total sent
    [SUM] 0.00-20.07 sec 392 MBytes 164 Mbits/sec
    Total received
    iperf Done.
    Done.
      Netduma-Fraser
      NetDuma Partner
      That's odd, are your ethernet cables compatible with gigabit?
      Put 1000/1000 in QoS and set to never and try again. Then also disable QoS completely in Anti-BB settings and try that.
      • FURRYe38's avatar
        I run only CAT6 LAN cables. Same cables that tested the XR450 and other routers.
        Those settings are default already after doing a factory reset. We expect routers to handle 900Mbps +- at factory defaults.
        1 Stream:
        [ 5] 0.00-1.00 sec 34.6 MBytes 290 Mbits/sec
        [ 5] 1.00-2.00 sec 36.8 MBytes 308 Mbits/sec
        [ 5] 2.00-3.00 sec 37.0 MBytes 310 Mbits/sec
        [ 5] 3.00-4.01 sec 37.5 MBytes 314 Mbits/sec
        [ 5] 4.01-5.01 sec 37.5 MBytes 314 Mbits/sec
        [ 5] 5.01-6.01 sec 37.4 MBytes 313 Mbits/sec
        [ 5] 6.01-7.01 sec 29.8 MBytes 249 Mbits/sec
        [ 5] 7.01-8.01 sec 37.5 MBytes 314 Mbits/sec
        [ 5] 8.01-9.02 sec 37.8 MBytes 316 Mbits/sec
        [ 5] 9.02-10.02 sec 37.5 MBytes 314 Mbits/sec
        [ 5] 10.02-11.02 sec 38.1 MBytes 319 Mbits/sec
        [ 5] 11.02-12.02 sec 37.8 MBytes 316 Mbits/sec
        [ 5] 12.02-13.02 sec 37.8 MBytes 316 Mbits/sec
        [ 5] 13.02-14.03 sec 36.9 MBytes 308 Mbits/sec
        [ 5] 14.03-15.03 sec 35.1 MBytes 294 Mbits/sec
        [ 5] 15.03-16.03 sec 37.2 MBytes 312 Mbits/sec
        [ 5] 16.03-17.03 sec 38.0 MBytes 318 Mbits/sec
        [ 5] 17.03-18.04 sec 30.5 MBytes 255 Mbits/sec
        [ 5] 18.04-19.04 sec 35.0 MBytes 292 Mbits/sec
        [ 5] 19.04-20.04 sec 20.9 MBytes 175 Mbits/sec
        [ 5] 20.04-21.04 sec 38.9 MBytes 325 Mbits/sec
        [ 5] 21.04-22.05 sec 39.1 MBytes 327 Mbits/sec
        [ 5] 22.05-23.21 sec 36.6 MBytes 263 Mbits/sec
        [ 5] 23.21-24.22 sec 38.5 MBytes 322 Mbits/sec
        [ 5] 24.22-25.22 sec 38.2 MBytes 320 Mbits/sec
        [ 5] 25.22-26.22 sec 31.1 MBytes 260 Mbits/sec
        [ 5] 26.22-27.23 sec 38.2 MBytes 321 Mbits/sec
        [ 5] 27.23-28.23 sec 38.9 MBytes 326 Mbits/sec
        [ 5] 28.23-29.23 sec 38.5 MBytes 322 Mbits/sec
        Sent
        [ 5] 0.00-30.00 sec 1.05 GBytes 302 Mbits/sec
        Received
        iperf Done.
        Done.
        4 Stream:
        [ 5] local 192.168.1.2 port 3661 connected to 192.168.0.136 port 5201
        [ 6] local 192.168.1.2 port 3662 connected to 192.168.0.136 port 5201
        [ 7] local 192.168.1.2 port 3663 connected to 192.168.0.136 port 5201
        [ 8] local 192.168.1.2 port 3664 connected to 192.168.0.136 port 5201
        [ 5] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
        [ 6] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
        [ 7] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
        [ 8] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
        [SUM] 0.00-1.17 sec 8.50 MBytes 61.0 Mbits/sec
        [ 5] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
        [ 6] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
        [ 7] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
        [ 8] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
        [SUM] 1.17-2.19 sec 8.50 MBytes 69.6 Mbits/sec
        [ 5] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
        [ 6] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
        [ 7] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
        [ 8] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
        [SUM] 2.19-3.20 sec 8.50 MBytes 70.5 Mbits/sec
        [ 5] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
        [ 6] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
        [ 7] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
        [ 8] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
        [SUM] 3.20-4.34 sec 8.50 MBytes 62.7 Mbits/sec
        [ 5] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
        [ 6] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
        [ 7] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
        [ 8] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
        [SUM] 4.34-5.37 sec 8.50 MBytes 69.6 Mbits/sec
        [ 5] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
        [ 6] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
        [ 7] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
        [ 8] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
        [SUM] 5.37-6.37 sec 8.50 MBytes 70.7 Mbits/sec
        [ 5] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
        [ 6] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
        [ 7] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
        [ 8] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
        [SUM] 6.37-7.55 sec 8.50 MBytes 60.8 Mbits/sec
        [ 5] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
        [ 6] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
        [ 7] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
        [ 8] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
        [SUM] 7.55-8.55 sec 8.50 MBytes 70.8 Mbits/sec
        [ 5] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
        [ 6] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
        [ 7] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
        [ 8] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
        [SUM] 8.55-9.71 sec 8.50 MBytes 61.6 Mbits/sec
        [ 5] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
        [ 6] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
        [ 7] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
        [ 8] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
        [SUM] 9.71-10.71 sec 8.50 MBytes 71.2 Mbits/sec
        [ 5] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
        [ 6] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
        [ 7] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
        [ 8] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
        [SUM] 10.71-11.73 sec 8.50 MBytes 69.9 Mbits/sec
        [ 5] 11.73-12.85 sec 3.75 MBytes 28.0 Mbits/sec
        [ 6] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
        [ 7] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
        [ 8] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
        [SUM] 11.73-12.85 sec 8.50 MBytes 63.5 Mbits/sec
        [ 5] 12.85-13.90 sec 2.75 MBytes 22.1 Mbits/sec
        [ 6] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
        [ 7] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
        [ 8] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
        [SUM] 12.85-13.90 sec 8.50 MBytes 68.2 Mbits/sec
        [ 5] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
        [ 6] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
        [ 7] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
        [ 8] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
        [SUM] 13.90-15.00 sec 8.50 MBytes 64.8 Mbits/sec
        [ 5] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
        [ 6] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
        [ 7] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
        [ 8] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
        [SUM] 15.00-16.14 sec 8.50 MBytes 62.7 Mbits/sec
        [ 5] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
        [ 6] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
        [ 7] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
        [ 8] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
        [SUM] 16.14-17.14 sec 8.50 MBytes 70.8 Mbits/sec
        [ 5] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
        [ 6] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
        [ 7] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
        [ 8] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
        [SUM] 17.14-18.33 sec 8.50 MBytes 60.0 Mbits/sec
        [ 5] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
        [ 6] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
        [ 7] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
        [ 8] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
        [SUM] 18.33-19.53 sec 8.50 MBytes 59.3 Mbits/sec
        [ 5] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
        [ 6] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
        [ 7] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
        [ 8] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
        [SUM] 19.53-20.58 sec 8.50 MBytes 67.9 Mbits/sec
        [ 5] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
        [ 6] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
        [ 7] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
        [ 8] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
        [SUM] 20.58-21.74 sec 8.50 MBytes 62.0 Mbits/sec
        [ 5] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
        [ 6] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
        [ 7] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
        [ 8] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
        [SUM] 21.74-22.74 sec 8.50 MBytes 71.1 Mbits/sec
        [ 5] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
        [ 6] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
        [ 7] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
        [ 8] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
        [SUM] 22.74-23.92 sec 8.50 MBytes 60.2 Mbits/sec
        [ 5] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
        [ 6] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
        [ 7] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
        [ 8] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
        [SUM] 23.92-25.04 sec 8.50 MBytes 64.0 Mbits/sec
        [ 5] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
        [ 6] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
        [ 7] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
        [ 8] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
        [SUM] 25.04-26.12 sec 8.50 MBytes 65.7 Mbits/sec
        [ 5] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
        [ 6] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
        [ 7] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
        [ 8] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
        [SUM] 26.12-27.20 sec 8.50 MBytes 65.9 Mbits/sec
        [ 5] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
        [ 6] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
        [ 7] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
        [ 8] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
        [SUM] 27.20-28.35 sec 8.50 MBytes 62.3 Mbits/sec
        [ 5] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
        [ 6] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
        [ 7] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
        [ 8] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
        [SUM] 28.35-29.53 sec 8.50 MBytes 60.3 Mbits/sec
        Sent
        [ 5] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
        Received
        Sent
        [ 6] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
        Received
        Sent
        [ 7] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
        Received
        Sent
        [ 8] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
        Received
        Total sent
        [SUM] 0.00-30.20 sec 268 MBytes 74.3 Mbits/sec
        Total received
        iperf Done.
        Done.
  • FURRYe38's avatar
    XR450 and iPerf
    5 Stream:
    [ 5] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
    [ 6] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
    [ 7] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
    [ 8] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
    [ 9] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
    [SUM] 0.00-1.01 sec 60.6 MBytes 505 Mbits/sec
    [ 5] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
    [ 6] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
    [ 7] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
    [ 8] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
    [ 9] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
    [SUM] 1.01-2.01 sec 60.6 MBytes 505 Mbits/sec
    [ 5] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
    [ 6] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
    [ 7] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
    [ 8] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
    [ 9] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
    [SUM] 2.01-3.02 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
    [ 6] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
    [ 7] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
    [ 8] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
    [ 9] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
    [SUM] 3.02-4.02 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
    [ 6] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
    [ 7] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
    [ 8] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
    [ 9] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
    [SUM] 4.02-5.02 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
    [ 6] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
    [ 7] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
    [ 8] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
    [ 9] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
    [SUM] 5.02-6.03 sec 60.6 MBytes 505 Mbits/sec
    [ 5] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
    [ 6] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
    [ 7] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
    [ 8] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
    [ 9] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
    [SUM] 6.03-7.03 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
    [ 6] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
    [ 7] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
    [ 8] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
    [ 9] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
    [SUM] 7.03-8.04 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
    [ 6] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
    [ 7] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
    [ 8] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
    [ 9] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
    [SUM] 8.04-9.04 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
    [ 6] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
    [ 7] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
    [ 8] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
    [ 9] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
    [SUM] 9.04-10.04 sec 60.6 MBytes 508 Mbits/sec
    [ 5] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
    [ 6] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
    [ 7] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
    [ 8] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
    [ 9] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
    [SUM] 10.04-11.05 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
    [ 6] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
    [ 7] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
    [ 8] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
    [ 9] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
    [SUM] 11.05-12.20 sec 60.6 MBytes 442 Mbits/sec
    [ 5] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
    [ 6] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
    [ 7] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
    [ 8] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
    [ 9] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
    [SUM] 12.20-13.20 sec 60.6 MBytes 508 Mbits/sec
    [ 5] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
    [ 6] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
    [ 7] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
    [ 8] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
    [ 9] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
    [SUM] 13.20-14.20 sec 60.6 MBytes 508 Mbits/sec
    [ 5] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
    [ 6] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
    [ 7] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
    [ 8] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
    [ 9] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
    [SUM] 14.20-15.21 sec 60.6 MBytes 505 Mbits/sec
    [ 5] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
    [ 6] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
    [ 7] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
    [ 8] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
    [ 9] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
    [SUM] 15.21-16.21 sec 60.6 MBytes 508 Mbits/sec
    [ 5] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
    [ 6] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
    [ 7] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
    [ 8] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
    [ 9] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
    [SUM] 16.21-17.22 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
    [ 6] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
    [ 7] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
    [ 8] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
    [ 9] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
    [SUM] 17.22-18.22 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
    [ 6] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
    [ 7] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
    [ 8] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
    [ 9] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
    [SUM] 18.22-19.22 sec 60.6 MBytes 508 Mbits/sec
    [ 5] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
    [ 6] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
    [ 7] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
    [ 8] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
    [ 9] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
    [SUM] 19.22-20.23 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
    [ 6] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
    [ 7] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
    [ 8] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
    [ 9] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
    [SUM] 20.23-21.23 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
    [ 6] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
    [ 7] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
    [ 8] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
    [ 9] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
    [SUM] 21.23-22.24 sec 60.6 MBytes 505 Mbits/sec
    [ 5] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
    [ 6] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
    [ 7] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
    [ 8] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
    [ 9] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
    [SUM] 22.24-23.25 sec 60.6 MBytes 506 Mbits/sec
    [ 5] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
    [ 6] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
    [ 7] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
    [ 8] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
    [ 9] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
    [SUM] 23.25-24.25 sec 60.6 MBytes 508 Mbits/sec
    [ 5] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
    [ 6] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
    [ 7] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
    [ 8] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
    [ 9] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
    [SUM] 24.25-25.25 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
    [ 6] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
    [ 7] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
    [ 8] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
    [ 9] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
    [SUM] 25.25-26.25 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
    [ 6] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
    [ 7] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
    [ 8] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
    [ 9] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
    [SUM] 26.25-27.26 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
    [ 6] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
    [ 7] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
    [ 8] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
    [ 9] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
    [SUM] 27.26-28.26 sec 60.6 MBytes 507 Mbits/sec
    [ 5] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
    [ 6] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
    [ 7] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
    [ 8] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
    [ 9] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
    [SUM] 28.26-29.27 sec 60.6 MBytes 506 Mbits/sec
    Sent
    [ 5] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
    Received
    Sent
    [ 6] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
    Received
    Sent
    [ 7] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
    Received
    Sent
    [ 8] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
    Received
    Sent
    [ 9] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
    Received
    Total sent
    [SUM] 0.00-30.00 sec 2.16 GBytes 618 Mbits/sec
    Total received
    iperf Done.
      Netduma-Fraser
      NetDuma Partner
      Thanks for that, I believe iPerf will be slower as we use very specific commands for that to ensure it operates optimally. The team are aware now so hopefully they can reproduce the issue.
  • FURRYe38's avatar
    Hoping to see improvements on the XR700. :smileywink:
  • FURRYe38's avatar
    I need to make a small correction with my initial test results.
    Those initial iPerf test results posted were testing the uplink speed of the WAN port. I wasn't paying attention when the test was running however looking at a network speed meter I have on my test PCs they show which direction the data flow is going, Up or DL. I didn't relize that the configuration of the PC thru the router and switch and how iPerf works and I had it configured, it seems having the iPerf Server configured on the PC thats connected to the switch and the iPerf client PC connected to the router under test, the direction of data flow is for the UP link speed. Changing the iPerf settings on the PC thats connected to the LAN switch to Client and the PC thats connected to the router under test to Server, this sends the data flow as DOWNLOAD link speed.
    So after checking things again, I reset the XR router again and ensured the PCs and iPerf was confgured for the DOWNLOAD speed test. Still not seeing anything close to 900mpbs unfortunately.
    Download Router mode
    1 Stream
    [ 5] 0.00-1.03 sec 25.1 MBytes 204 Mbits/sec
    [ 5] 1.03-2.03 sec 30.1 MBytes 252 Mbits/sec
    [ 5] 2.03-3.03 sec 38.8 MBytes 325 Mbits/sec
    [ 5] 3.03-4.03 sec 38.9 MBytes 326 Mbits/sec
    [ 5] 4.03-5.04 sec 37.9 MBytes 316 Mbits/sec
    [ 5] 5.04-6.04 sec 22.9 MBytes 191 Mbits/sec
    [ 5] 6.04-7.04 sec 31.2 MBytes 262 Mbits/sec
    [ 5] 7.04-8.04 sec 38.8 MBytes 324 Mbits/sec
    [ 5] 8.04-9.05 sec 31.6 MBytes 265 Mbits/sec
    [ 5] 9.05-10.05 sec 38.5 MBytes 323 Mbits/sec
    [ 5] 10.05-11.05 sec 38.2 MBytes 320 Mbits/sec
    [ 5] 11.05-12.05 sec 23.4 MBytes 196 Mbits/sec
    [ 5] 12.05-13.05 sec 31.4 MBytes 262 Mbits/sec
    [ 5] 13.05-14.06 sec 39.2 MBytes 328 Mbits/sec
    [ 5] 14.06-15.06 sec 38.5 MBytes 322 Mbits/sec
    [ 5] 15.06-16.06 sec 31.2 MBytes 261 Mbits/sec
    [ 5] 16.06-17.07 sec 38.9 MBytes 325 Mbits/sec
    [ 5] 17.07-18.07 sec 38.9 MBytes 326 Mbits/sec
    [ 5] 18.07-19.07 sec 31.2 MBytes 262 Mbits/sec
    [ 5] 19.07-20.07 sec 30.1 MBytes 252 Mbits/sec
    [ 5] 20.07-21.07 sec 30.1 MBytes 252 Mbits/sec
    [ 5] 21.07-22.08 sec 21.8 MBytes 182 Mbits/sec
    [ 5] 22.08-23.08 sec 29.1 MBytes 244 Mbits/sec
    [ 5] 23.08-24.08 sec 31.2 MBytes 261 Mbits/sec
    [ 5] 24.08-25.08 sec 38.6 MBytes 323 Mbits/sec
    [ 5] 25.08-26.08 sec 38.8 MBytes 324 Mbits/sec
    [ 5] 26.08-27.09 sec 31.2 MBytes 262 Mbits/sec
    [ 5] 27.09-28.09 sec 31.0 MBytes 260 Mbits/sec
    [ 5] 28.09-29.09 sec 37.4 MBytes 313 Mbits/sec
    [ 5] 29.09-30.09 sec 30.0 MBytes 251 Mbits/sec
    Sent
    [ 5] 0.00-30.33 sec 996 MBytes 275 Mbits/sec
    Received
    4 Stream
    [ 5] 0.00-1.02 sec 5.12 MBytes 42.3 Mbits/sec
    [ 6] 0.00-1.02 sec 5.12 MBytes 42.3 Mbits/sec
    [ 7] 0.00-1.02 sec 5.00 MBytes 41.3 Mbits/sec
    [ 8] 0.00-1.02 sec 5.00 MBytes 41.3 Mbits/sec
    [SUM] 0.00-1.02 sec 20.2 MBytes 167 Mbits/sec
    [ 5] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
    [ 6] 1.02-2.02 sec 5.38 MBytes 45.0 Mbits/sec
    [ 7] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
    [ 8] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
    [SUM] 1.02-2.02 sec 20.2 MBytes 169 Mbits/sec
    [ 5] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
    [ 6] 2.02-3.02 sec 6.12 MBytes 51.3 Mbits/sec
    [ 7] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
    [ 8] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
    [SUM] 2.02-3.02 sec 20.2 MBytes 170 Mbits/sec
    [ 5] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
    [ 6] 3.02-4.03 sec 1.62 MBytes 13.6 Mbits/sec
    [ 7] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
    [ 8] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
    [SUM] 3.02-4.03 sec 20.2 MBytes 169 Mbits/sec
    [ 5] 4.03-5.03 sec 1.88 MBytes 15.7 Mbits/sec
    [ 6] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
    [ 7] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
    [ 8] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
    [SUM] 4.03-5.03 sec 20.2 MBytes 170 Mbits/sec
    [ 5] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
    [ 6] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
    [ 7] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
    [ 8] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
    [SUM] 5.03-6.03 sec 20.2 MBytes 169 Mbits/sec
    [ 5] 6.03-7.03 sec 4.00 MBytes 33.5 Mbits/sec
    [ 6] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
    [ 7] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
    [ 8] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
    [SUM] 6.03-7.03 sec 20.2 MBytes 170 Mbits/sec
    Sent
    [ 5] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
    Received
    Sent
    [ 6] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
    Received
    Sent
    [ 7] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
    Received
    Sent
    [ 8] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
    Received
    Total sent
    [SUM] 0.00-30.34 sec 392 MBytes 109 Mbits/sec
    Total received
    Duckware still reports same:
    BPS=370,396,672
    0: 43,215,838 (345,726,704 bps)
    1: 44,711,842 (357,694,736 bps)
    2: 45,684,960 (365,479,680 bps)
    3: 46,070,614 (368,564,912 bps)
    4: 46,952,917 (375,623,336 bps)
    5: 46,035,429 (368,283,432 bps)
    6: 46,825,266 (374,602,128 bps)
    7: 46,501,707 (372,013,656 bps)
    8: 46,668,326 (373,346,608 bps)
    9: 46,320,527 (370,564,216 bps)
    10: 46,748,672 (373,989,376 bps)
    11: 46,432,389 (371,459,112 bps)
    12: 45,312,645 (362,501,160 bps)
    13: 46,491,542 (371,932,336 bps)
    14: 46,208,458 (369,667,664 bps)
    15: 46,506,975 (372,055,800 bps)
    16: 46,208,476 (369,667,808 bps)
    17: 46,794,457 (374,355,656 bps)
    18: 46,392,063 (371,136,504 bps)
    19: 46,824,360 (374,594,880 bps)
  • FURRYe38's avatar
    As a side test, I had my XR700 in AP mode and wanted to see what speeds were seen while in this mode:
    Download Speed AP mode
    4 Stream
    [ 5] 0.00-1.12 sec 2.25 MBytes 16.9 Mbits/sec
    [ 6] 0.00-1.12 sec 2.25 MBytes 16.9 Mbits/sec
    [ 7] 0.00-1.12 sec 2.25 MBytes 16.9 Mbits/sec
    [ 8] 0.00-1.12 sec 2.12 MBytes 15.9 Mbits/sec
    [SUM] 0.00-1.12 sec 8.88 MBytes 66.5 Mbits/sec
    [ 5] 1.12-2.36 sec 2.50 MBytes 16.9 Mbits/sec
    [ 6] 1.12-2.36 sec 2.50 MBytes 16.9 Mbits/sec
    [ 7] 1.12-2.36 sec 2.50 MBytes 16.9 Mbits/sec
    [ 8] 1.12-2.36 sec 2.62 MBytes 17.7 Mbits/sec
    [SUM] 1.12-2.36 sec 8.88 MBytes 59.9 Mbits/sec
    [ 5] 2.36-3.43 sec 2.00 MBytes 15.6 Mbits/sec
    [ 6] 2.36-3.43 sec 2.00 MBytes 15.6 Mbits/sec
    [ 7] 2.36-3.43 sec 2.00 MBytes 15.6 Mbits/sec
    [ 8] 2.36-3.43 sec 1.88 MBytes 14.7 Mbits/sec
    [SUM] 2.36-3.43 sec 8.88 MBytes 69.4 Mbits/sec
    [ 5] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
    [ 6] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
    [ 7] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
    [ 8] 3.43-4.53 sec 1.62 MBytes 12.5 Mbits/sec
    [SUM] 3.43-4.53 sec 8.88 MBytes 68.1 Mbits/sec
    [ 5] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
    [ 6] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
    [ 7] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
    [ 8] 4.53-5.66 sec 2.00 MBytes 14.9 Mbits/sec
    [SUM] 4.53-5.66 sec 8.88 MBytes 65.9 Mbits/sec
    Sent
    [ 5] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
    Received
    Sent
    [ 6] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
    Received
    [ 6] 0.00-30.29 sec 57.5 MBytes 15.9 Mbits/sec
    Sent
    [ 7] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
    Received
    [ 7] 0.00-30.29 sec 57.5 MBytes 15.9 Mbits/sec
    Sent
    [ 8] 0.00-30.29 sec 57.6 MBytes 16.0 Mbits/sec
    Received
    [ 8] 0.00-30.29 sec 57.5 MBytes 15.9 Mbits/sec
    Total sent
    [SUM] 0.00-30.29 sec 230 MBytes 63.8 Mbits/sec
    Total received
    [SUM] 0.00-30.29 sec 230 MBytes 63.7 Mbits/sec
    UpSpeed AP mode
    4 Stream
    bin/iperf3.exe -c 192.168.0.136 -P 4 -i 1 -p 5201 -f m -t 20
    Connecting to host 192.168.0.136, port 5201
    [ 5] local 192.168.0.148 port 2881 connected to 192.168.0.136 port 5201
    [ 6] local 192.168.0.148 port 2882 connected to 192.168.0.136 port 5201
    [ 7] local 192.168.0.148 port 2883 connected to 192.168.0.136 port 5201
    [ 8] local 192.168.0.148 port 2884 connected to 192.168.0.136 port 5201
    [ 5] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
    [ 6] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
    [ 7] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
    [ 8] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
    [SUM] 0.00-1.00 sec 74.5 MBytes 624 Mbits/sec
    [ 5] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
    [ 6] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
    [ 7] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
    [ 8] 1.00-2.00 sec 17.8 MBytes 149 Mbits/sec
    [SUM] 1.00-2.00 sec 74.5 MBytes 624 Mbits/sec
    [ 5] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
    [ 6] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
    [ 7] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
    [ 8] 2.00-3.01 sec 19.1 MBytes 159 Mbits/sec
    [SUM] 2.00-3.01 sec 74.5 MBytes 621 Mbits/sec
    [ 5] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
    [ 6] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
    [ 7] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
    [ 8] 3.01-4.08 sec 15.1 MBytes 119 Mbits/sec
    [SUM] 3.01-4.08 sec 74.5 MBytes 585 Mbits/sec
    [ 5] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
    [ 6] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
    [ 7] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
    [ 8] 4.08-5.08 sec 14.2 MBytes 119 Mbits/sec
    [SUM] 4.08-5.08 sec 74.5 MBytes 624 Mbits/sec
    Sent
    [ 5] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
    Received
    Sent
    [ 6] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
    Received
    Sent
    [ 7] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
    Received
    Sent
    [ 8] 0.00-20.03 sec 342 MBytes 143 Mbits/sec
    Received
    Total sent
    [SUM] 0.00-20.03 sec 1.34 GBytes 574 Mbits/sec
    Total received
    Seeing around 600Mpbs here.
    It's interesting that Duckwares test saw 900mbps while in AP mode:
    BPS=945,153,424
    0: 118,618,928 (948,951,424 bps)
    1: 118,005,184 (944,041,472 bps)
    2: 118,211,457 (945,691,656 bps)
    3: 118,307,869 (946,462,952 bps)
    4: 118,317,792 (946,542,336 bps)
    5: 118,320,105 (946,560,840 bps)
    6: 117,452,558 (939,620,464 bps)
    7: 118,312,032 (946,496,256 bps)
    8: 118,319,123 (946,552,984 bps)
    9: 118,246,052 (945,968,416 bps)
    10: 117,973,528 (943,788,224 bps)
    11: 117,933,981 (943,471,848 bps)
    12: 118,321,485 (946,571,880 bps)
    13: 117,904,900 (943,239,200 bps)
    14: 118,323,900 (946,591,200 bps)
    15: 118,319,751 (946,558,008 bps)
    16: 117,919,242 (943,353,936 bps)
    17: 118,305,083 (946,440,664 bps)
    18: 118,313,001 (946,504,008 bps)
    19: 117,931,813 (943,454,504 bps)
    • -Donovan-'s avatar
      -Donovan-
      Luminary
      BPS=945,153,424
      I saw another interesting thing too in the setup wizard at the Checking internet speed on the WAN Port, the speedtest can read the correct speed at 940Mbps/50Mbps and sometime is totally way off. Once the setup is done and you redo a speed test, you can't get the gigabit speed on ISP speed test or speedtest.net.
        Netduma-Fraser
        NetDuma Partner
        Thank you for the updated information, I have asked for news on the matter from the team.
