surround
Apr 04, 2016Star
Netgear C6300 wifi not working with samsung galaxy s7 edge and regular s7
I have s7 edge and regular s7. I have 200mbps with time warner and have the netgear c6300. It won't connect properly to app store, youtube, oculus store etc. The iphones in my house work perfectly, as do my computers and laptops. The s7 phones work fine on other wifi connections, just not at home. Help!
- Samsung recently released a software update and now I'm able to watch YouTube videos and update my apps on the Google play store. I got my phone from T-Mobile so idk if the other phone companies have released the update yet. I hope this is a permanent fix to the problems and not a temporary one like the fixes I found here. I don't have the money to buy another router and I've just been waiting for the WiFi problem to get fixed so I can use my phone at home.
- SteverenoInitiate
I am having the same problem with my Galaxy S7 and Netgear C6300 with Comcast/Xfinity service. The phone connects to the Wifi but no internet service. Our Galaxy S4 and LG G3 phones worked fine.
- SteverenoInitiate
I took the Galaxy S7 to the Verizon store and they could not make it work right on their wifi either, so they are going to replace the phone. But I have to wait a week until they get more in stock.
- tryagen2Tutor
In reply to KIt3505, the wireless card list approach did not work for me, I tried the steps 3x and lost my connection each time. I purchased my phone from the samsung kiosk at bestbuy. It worked fine when they set it up there. When I got home I immediately started having download problems when I connected it to my network. I also noticed that the security code that the S7 edge did not match the WPA2 PSK that my network has. I wish that I had wrote it down it looked nothing like the WPA2. I took the phone back the very next day, again the samsung associate at the bestbuy showed me that it was downloading fine on ddifferent Networks. You only have 14 days to decide before returning the phone. I went pass the time limit.
At&t is my Network carrier, I can not use the My at&t app to connect to there network. I get an error L354 message telling me that there is a connection problem. I took the phone to the AT&T store and the salesman had no problem connecting to the AT&T Network and downloading apps from the google play store.
I also discovered that if I go to my routerlogin screen and go to my wireless page, and change my security settings from WPA2 PSK to the open security settings button and apply those settings I have to reconnect to the router. But, when I go to the play store on the phone some of the apps at the play store are visible and I am able to download them using wifi. That is why I know that it is a "Security" problem between the S7 edge and the netgear c6300.
Time Warner Cable is my internet service provider they suggested that the c6300 was compatible to there system. They need to push an security upgrade to the router, or the Netgear manufactures should upgrade the firmware to the latest available security. AT&T may have some responsibility, but, Stevereno mentioned he had Verizon as his carrier. We are in the dark on this issue. I know that with all the hacking of networks and buisnesses, I am not above resonable compensation to maintain up to date security.
- I have the same issue and even got a replacement phone and it had the same issue. Can connect on public wifi, any other wifi, and twc with a different router, but not using netgear c6300. No other devices have an issue. I can surf the Web bUT can't use oculus or Google play.
Yup, still having same problems, no google play store, oculus store etc. Are we going to get a solution?
I have contacted Samsung, TWC and Netgear with no luck. If I have to replace this router, that is not even 6 months old, I will replace it with another brand.
- fauschakInitiate
Same here: Samsung S7 edge, Netgear C6300, Time Warner.
This is a paste of the message I've posted in "androidcentral"
Same exact situation in my case.
S7 edge, Time Warner, Netgear c6300.
I can see YouTube videos on Chrome browser or Firefox, but I cannot see videos on YouTub app.
At the office's WiFi, YouTube app works without problems.Apps that do not work:
YouTube
Netflix
Google Store
Google Newstand
Apps that work:
Gmail
Inbox
Email
Browsers
Bunch of financial applications (Chase, Bofa, Venmo, Mint)I rebooted the router, I've changed the type of WiFi security(I haven't tried no security, yet).
I rebooted the phone many times.
I deleted the WiFi connection on the phone and re-added it.
I removed updates and new applications and reloaded them.
I deleted cache contents, forced stop and restarted.
All other phones and laptops work fast and flawlessly.I'm thinking on hooking up some Lan Analyzer to check the TCP/UDP traffic, but I hope someone finds out the answer sooner...
I'm also thinking on trying a VPN to see if hiding the content of the packet has some effect.
I hope that Time Warner is not throttling traffic.
Could the applications for Samsung 7 with Android Marshmallow we the cause of the problem?
So many questions...
- fauschakInitiate
Well... I found a solution, but it's not pretty.
I've tried by replacing the Netgear C3600 (which I bought and own) with TimeWarner's Ubee DDW36C (leased at 10 $/mo for router and 5$/mo for WiFi -- can you believe it?!)
Now everything's work exactly as expected.
YouTube, Netflix, Google Store, Google Inbox, BeyondPod, ...
What could be wrong with the Netgear C3600?
Ugh!
- tryagen2Tutor
I have windows 10 os with a C6300 cable modem router. The Firmware Version of the router is v1.02.19. I am not quite certain but I believe the netgear genie version is 2.4.26. I also have a problem with the wifi not working mainly when I try to go to the play store and download apps, and keeping my apps updated. I have problems connecting to the Occulus store and downloading.
I have been working around the problem by turning off the wifi and using the 4G network to download apps and to keep my apps updated. This can be costly if you are on a limited data plan.This is not the solution to the wifi problem.
I, also checked at my routerlogin and noticed that the security that was set on the routerlogin page was different than the security code that was being used for the samsung s7 edge connection to the router.
this could be why we are not connecting to the router.
- MinsMiniTutor
I’ve had constant problems since I got my "1st " Samsung Galaxy S 7 Edge. I spend almost 3 hours the 1st night trying to transfer everything from my old phone to the new one. It would show and recognize my wi-fi but “no connectivity “ or “no internet connection” would pop up. A Verizon rep had me try several things. The only way we could do anything was to take it off wi-fi and only use mobile data. After a day of several hours on the phone with Verizon, Time Warner and rebooting my router several times and a trip to the Verizon store. I had Verizon order me another phone. “2nd” phone exact same problems. Again, I called Verizon, Time Warner and rebooted my router. After several hours on the phone and another trip to Verizon, no one seemed to know what else to do. Verizon suggested I call Samsung support. Samsung wanted me to do all the same things that Verizon already had me do on the 1st phone and again on the 2nd one. At that point they said I could send the phone off to Samsung for “repair” which would take 10-14 days to receive it back. I felt I should Not have to send a new $792 phone off to repair. I called Verizon back and told them to order me another phone. I have to say, Verizon has been great. Every rep and tech has been putting notes on my account on all my calls and all the things that they had me do to try fixing the problem. Now, on my “3rd” phone, Yes, same problems! The same day I received it, I called Verizon and they said customer service couldn’t order me my “4th” phone but their tech department could or I could go into the Verizon store to turn in that phone and get a new one. The Verizon rep was putting notes on my account to not charge me a restocking fee or any other extra charges. I went to the Verizon store intending on turning in my 3rd phone and getting a 4th one. Then my son found this site and these posts. I sat in front of the store reading these posts and found the post about a work around. Went home to try it. It worked, for a day. Back to the same wi-fi problems. Keeps saying I don’t have an internet connection, can’t download apps, can’t sign in on my yahoo email. I tried to do the work a around again on my Netgear on line, now it doesn’t work at all. The only way to do anything on my phone when I’m home is to use my mobile data and use my data up. Obviously sending my phone to Samsung for repair wouldn’t work because they would say it’s fine and just send it back to me and I Still wouldn’t be able to use the wi-fi at home. I did check and my Netgear C6300 has the latest firmware. Netgear, Samsung come on…….fix the problem, come up with an update ASAP!!!!!!!!
Yeah, i don't think its the phone. I've used my galaxy s7 edge on other wifi routers with no problem. It has to be a problem with the c6300.
- MinsMiniTutorI agree, I've used it at a couple others as well. I can't trust it to be using my wi-first instead of my data. At home I keep mobile data off.
- tryagen2TutorIt is nice to see that DarrenM a moderator and the engineers at Netgear are looking into this problem. I hope that a solution can be found.
Seeing as how there are so many Galaxy phones out there, I hope the fix comes soon.
From other message boards Samsung has had this issue with other phones and devices as well. I have never purchased tech the day it was released and against my better judgement I did it with this phone and am seriously regretting my decision. It looks like my only option is to replace the router with something else. Supposedly if you disable the IPV6 on the router will fix the issue but this option does not seem to be available. I have scoured the manual, device interface and nothing about being able to actually do it. Anyone able to tell us if we can disable the IPV6 on the C6300 router or not?
- snuphiluphigusAspirant
I'm in the same boat and waiting for an answer. Here is the background of what I have tried and with whom I have worked. Again, phone works on C6300 router for all applications and services excluding Google Play Services.
Time Warner Cable: C6300, V1.02.19 (only supported firmware version)
Verizon: Samsung Galaxy S6 (SM-G920V) with April 2, 2016 6.0.1 update (hmmm, this is when it stopped working)
Set 2.4Ghz wireless network to open (no security) with the access control allowed for my phones MAC: No success
Set 2.4Ghz wireless network to different security configurations, i.e. WEP, WPA2, TKIP & AES: No success
Set port forwarding for both TCP/UDP port 5228: No success
Spoke with Time Warner network technician to ensure they weren't blocking TCP/UDP port 5228
Disabled and cleared cache of Google Play Services, Download Manager, Google Play Store: No success
Reset phone to factory and started over: Works great on other wireless networks just not with the C6300.
Spoke with Verizion Customer Service: You already know I didn't get anywhere with them.
Not going to waste my money talking with Netgear.
Conclusion: There is a security association issue with the 6.0.1 phone software and the current Netgear router firmware V1.02.19 or possibly some routing issue like IPV6 that is causing it to loop or not forward. Either way, only the bubbas with the access will be able to test and resolve this issue. If not resolved within 30 days, I will contact Netgear for a refund/replacement since I am still within warranty.
I was able to setup a guest network with no security, hidden SSID, and turned on network security so only my phone is using this network and I am now able to connect to Google Play Services. Kudos to whoever found this work around.
- tryagen2Tutor
Excellent work around snuphiluphigus. Setting up the guest network with security is the answer for the S7 phones.
- TrippinTripsAspirant
I have two Galaxy s7s and am having the same problem. I've tried absolutely everything with customer support from google, Time Warner Cable, Netgear, T-mobile (my carrier) and Samsung as well as every workaround listed across every forum I can find. None of it works. Has anyone found any solutions?
I've reset the cache, factory reset the phone, reset the modem, created a guest network with no security, added the phones to my access list, and literally everything else I can think of. None of it works.
- MinsMiniTutor
I've been on the phone with Netgear for 90 minutes tonight with 2 techs. They set me up on as a guest, but it did Not work. Netgear engineers are aware of the problem and are working on a firmware update. They explained on what all has to happen for them to put out a firmware update. Once their engineers come out with an update, they have to contact every company, like Time Warner, Comcast, ATT, Cox, Charter etc. that provides internet and they need to get a certification to be able to be set up on the internet companies system for the updated firmware to be out out. In other words, it doesn't happen over night. They said it would be months and months, if at all when an update would be able to be released. They assured me that no other routers have this problem with the Samsung Galaxy S7 and S7 Edge. It's this exact router/modem with this exact model of phone. They apologized many times and said that this problem is their fault. They said I can check back with them to see if any firmware update has been certified and approved to fix the problem. But they said at this point there is nothing else to be done. I will either go to my cable company and pay a monthly fee for one or buy another router. Since my son gave this router/modem to me, I will see if he wants to sell it. I don't know about any of you out there with this same problem, but I am Done with it not working when I'm at home. There isn't a fix! There will Not be a fix for months and months if at all! Good luck to all of you. I will continue to read everyone's posts and add any info if I can help.
Right now the only solution seems to be getting a different router. I spent a vast amount of time and worked with different "experts" to no avail. I was tired of it not working so I jumped ship. On a plus side my phone now works and our internet speeds are faster with this new router.
Well, I couldn't take it any more. I bought a new router. I'll never buy another netgear anything. Thanks for nothing. And I'll lt everyone know not to buy any of their stuff either.
- justduckyAspirant
Thanks for this info. I do want to clarify that it is not just the Samsung Galaxy S7. Me and my daughter have the Samsung Galaxy S6. The issues(all of them) are happening to our phones also. They started after we did the Marshmallow Update. I am really disgusted that Netgear would not even talk to me unless I agreed to pay $139.99 to check my router. My modem/router is a little over a year old and I paid over $200 and the only response from Netgear is "Do you think this is our fault?" Never buying Netgear again!
- MinsMiniTutor
I'm still communicating with Netgear. I'm waiting to hear back from them, should be in the next day or two. They have been phenominal with me. Every tech person and supervisor I have spoken to have been extremely nice and apologetic. I have the names of every person that has helped me and they all follow up with me when they say they will. We are working on a resolution. I believe in Netgear's products and their people. This is a bizarre situation for them as well.
I gave up and jumped ship to another brand of modem. I am never using Netgear again as long as I live. This entire situation was just so ridiculous.
