NWMichelle's avatar
Feb 05, 2019
I can't log in with admin/password... R7000
I am trying to login and see what's on my network (and to get my RING devices on the right 2.4 channel) but the website will NOT accept admin and password AND it will not accept my serial number (the "continue" box stays gray after I enter the serial number). I am ready to throw this whole thing away! I have hit the "reset" button, turned it off/on, and NO LUCK. What the heck is next??? I have the Nighthawk R7000 series
  • PBukowski's avatar
    PBukowski
    Sep 17, 2019
    Thank you to everyone who provided suggestions. I ended up downloading the Netgear app ( I forgot the exact name, maybe Netgear UP) and was finally able to get into the login screen where all the router settings are located.
    I then had to reset all the parameters fresh and now it’s working fine.
  • are you trying to connect to the router'e GUI at http://192.168.1.1 ?
    if so, it should not ask you for any serial numbers, only user and admin which by default are "admin" and "password"
    • antinode's avatar
      antinode
      Guru
      > [...] I have hit the "reset" button, [...]
         "hit" how, exactly?  Visit http://netgear.com/support , put in your
      model number, and look for Documentation.  Get the User Manual.  Look
      for "Factory Settings".
      > [...] I have the Nighthawk R7000 series
         "series"?  R7000?  R7000P?
      > [...] it should not ask you for any serial numbers, [...]
         That's part of the (generally defective) password recovery scheme
      found in recent firmware versions.  Disabling it (if you ever get in)
      may be the best course.
      • NWMichelle's avatar
        NWMichelle
        Tutor
        Reset button= hole on back of box. I read on another thread to try that to reset to factory settings in case I had changed the user name/password combo (though I am nearly certain I never did).  And it's just the R7000. It's a few years old....maybe that is the problem. Sigh.
      NWMichelle
      Tutor
      Yes. I tried that address. I tried all this: By default, your NETGEAR home router's IP address should be assigned as either 192.168.1.1 or 192.168.0.1. You should also be able to access your router by typingin http://www.routerlogin.net or http://www.routerlogin.com into your web browser's address bar.
      Then when at the page with admin/password, if you click cancel, it wants you to put in your serial number. It won't let me move past that screen.
  • michaelkenward's avatar
    michaelkenward
    There is support material, including a manual, for the R7000 somewhere at the end of this link:
    >>>> R7000 | Product | Support | NETGEAR <<<<
    For the R7000P, try here:
    >>> R7000P | Product | Support | NETGEAR <<<
    What are you trying to login with and how?
    Browser? Desktop app? Mobile app?
    Connecting to routerlogin.net? An IP address?
    Did you find this?
    If you cannot login to your router | Answer | NETGEAR Support
    It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
      NWMichelle
      Tutor
      I have the manual. I have read the manual.
      Thank you for the links.
      I tried to log in via my computer, via IP address and web addresses. I also downloaded the app to my phone, with no luck either.
      It is plugged into a modem (at work right now, and can't recall the name of it--lol....it's white!)
      The frustrating part is that it DID just work a few months ago...piece of cake! I've done nothing to since then and now I can't access it.
      Thanks for that last link. I will work through that at home after work. I appreciate the help.
        michaelkenward
        Did we ever find out what the modem is in front of this router?
  • What mode is the R7000 in? Router or Access Point mode? Don't know the difference? Check the manual for Access Point Mode.
  • To the original poster: I have the very same problem. Happened after firmware update. Everything works, but I can no longer login as an admin, and the router will not accept the serial number to “recover password”. The best I could find out was to do factory reset and reprogram everything again. Did you find out anything else that was useful?
    What a PITA!
      PBukowski
      I’ve also tried everything and cannot access router login.com or router login.net. It was surfing just fine, but I needed to change some settings and I can no longer get into it. I’ve also tried a direct cat 5 wire between port 2 and the computer. Then I’ve tried WiFi and still no login page. I end up with the netgear web site, instead of the router login screen.
      Now I held reset for 7 seconds until the power light flashes, to default it to factory settings. After all that I still can’t log into it. It surfs the internet though. Ughh, is there a fix for this? I’ve always been really good about keeping the firmware updated. I suspect the latest firmware is preventing me from being able to log into it.
      • antinode's avatar
        antinode
        Guru
        > I've also tried everything [...]
           It would have made more sense to start your own new thread, instead
        of re-awakening this months-old, largely unproductive thread.
           Think for a moment about how little useful information that that
        non-description could possibly convey to the non-psychics in your
        audience.  If you had actually "tried everything", then there would be
        no hope at all.
        > [...] cannot access router login.com or router login.net. [...]
           "router login.com or router login.net" should be "routerlogin.com or
        routerlogin.net" (without spurious spaces).  What, exactly, did you try?
        Did you try specifying the router's IP address instead of any of these
        names?
           "cannot" is not a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions with their actual results (error messages, LED
        indicators, ...) can be more helpful than vague descriptions or
        interpretations.
        > [...] I can no longer get into it. [...]
           Regarding "can no longer", see "not a useful problem description
        [...]", above.
        > [...] Then I've tried WiFi and still no login page. [...]
           Now that you've revealed what you did _not_ get, perhaps you could
        reveal what you _did_ get.
        > [...] I end up with the netgear web site, [...]
           "the netgear web site" is a very big place.  Which part of it did you
        get?  Copy+paste is your friend.
        > [...] I still can't log into it. [...]
           Regarding "can't", see "not a useful problem description [...]",
        above.
           LED indicators?  Visit http://netgear.com/support , put in your model
        number, and look for Documentation.  Get the User Manual.  Read.  Look
        for the LED descriptions and "Troubleshoot".  Especially "Cannot
        Log In to the Router".
      michaelkenward
      Maybe, maybe not. There can be many reasons why people see these "can't login" symptoms. Without knowing the exact circumstances, who knows which applies to you.
      Let's deal with this bit:
      ComPH wrote:
      ....the router will not accept the serial number to “recover password”.
      You don't say what "will not accept" means, but there is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a closed loop.
      If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
      If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
      As to this bit:
      ComPH wrote:
      Everything works, but I can no longer login as an admin, ...
      That's an other one where there can be various causes. Sometimes you can recover simply by rebooting your network so that the various components connect in the right order:
      • Turn off and unplug modem.
      • Turn off router and computers.
      • Plug in and turn on modem. Wait 2 minutes for it to connect.
      • Turn on the router and wait 2 minutes for it connect.
      • Turn on computers and rest of network.
      If that doesn't get you back in business,  then we need to know more. In particular, what is the modem in front of your router? If it is one of those things that an Internet service provider wished on you, then it may also be a router, with ports to wire things to your network and maybe with its own wifi. If so, you may need to reconfigure the modem and/or the Netgear router.
      For guidance on that, provide more information and perhaps start a new discussion. When problem solving it is generally a good idea to start a new conversation, after checking old stuff for clues, of course.
      That issue crops up all the time and you should be able to find an existing answer that fits your circumstances.
      Good luck. You may need it.
