orbi 870 series
34 TopicsMost online devices not showing on on device list after router reboot
I did a reboot on my Orbi 870 system last night. Since doing this, on a few of my devices are showing on the connected device list on the router. I have around 30 devices connected to the system but only a handful are showing on the device list list the reboot. I have 3 satellites connected via wireless backhaul. All are showing a good connection. However all are showing IP's of 0.0.0.0. Has anyone come across this and have a solution?3Views0likes0CommentsAttached Devices list shows for about a day then is not available on web app for RBE871
Hi, The Attached Devices list shows for about a day then is not available on web app for RBE871. I do a reboot then the attached devices show again for about a day. Router RBE871 V10.5.20.4_1.3.5 Satellite1 RBE870 V10.5.20.4 Satellite2 RBE870 V10.5.20.4 Satellite3 RBE770 V10.5.20.3 Any suggestions on how to fix this or is this just a firmware bug? Everything else works great - i get great internet all around/outside the house. Its just the attached device list issue- Thanks!430Views1like26CommentsOrbi 870 -and Disney+ problems
Hi, I replaced my Fritzboxes with an Orbi 870 Mesh and since then I have not been able to use Disney+: Internet via Vodafone VDSL Draytek Vigor 167 as modem (nothing configured, just plugged in and PPoE set in Orbi) I have not configured anything else in Orbi, no Armor etc. Disney apps iOS/tvOS give me an error #93 (access blocked, e.g. due to VPN (which is not the case)). Login via browser results in ‘Sorry, an unexpected error has occurred. Please try again later.’ I can start Disney without any problems on another Wi-Fi network or via mobile data. Someone here in the community wrote that you have to set iPV6 to DHCP, another said you should turn it off completely – I tried both without success. I'm at a dead end. Trying everything is beyond my patience (turn off, wait 2 minutes, start up the modem, wait, start up the router...). So I hope you have a tip for me. Best regards, HeikoSolved185Views0likes13CommentsOrbi 870 und Disney+
Hi, ich habe meine Fritzboxen durch ein Orbi 870 Mesh ersetzt und kann seitdem Disney+ nicht mehr nutzen: Internet über Vodafone VDSL Draytek Vigor 167 als Moden (nichts konfiguriert, nur angestöpselt und PPoE im Orbi eingestellt) Im Orbi ist auch nichts weiter von mir konfiguriert, kein Armor etc. Disney-Apps iOS/tvOS werfen einen Fehler 93 aus (Zugang gesperrt z.B. wg. VPN (was nicht zutrifft)) Anmeldung im Browser wirft nur den Fehler "Sorry, an unexpected error has occurred.Please try again later." In einem anderen WLAN oder über Mobilfunk kann ich problemlos Disney starten. Ich bin ratlos. Hier in der community schrieb jemand, man müsse iPV6 auf DHCP stellen, ein anderer man solle es ganz ausschalten - ich habe beides erfolglos probiert. Alles einfach durchzuprobieren sprengt auch meine Geduld (ausschalten, 2 Minuten warten, Modem hochfahren, warten, Router hochfahren...). Daher hoffe ich, dass Ihr einen Tipp für mich habt. Liebe Grüße, HeikoSolved38Views0likes1CommentOrbi 870 - Options Missing from Web Interface
I am setting up my newly purchased Orbi 871 (Router + 2 satellites) and have noticed that under Advanced-->Security, I have only the Access Control option. I am wondering what happened to the Block Services, Block Sites, EMail, and Schedule options that I had with prior Orbi routers. I have the latest firmware and my Armor subscription is active. Has anyone experienced this and if so, is there a solution?Solved46Views0likes1CommentIssue with various apps on android devices
Since upgrading to the 870 mesh system various apps on my wife's android phone aren't loading. Everything is fine on iOS devices but apps such and the BBC News app are failing to load on the android phone. I really don't understand what's causing this as it seems to only affect android devices. Has anyone found a solution to this?150Views0likes19CommentsRBE871 slow speed
Hi All, just installed my brand new RBE871 and I’m getting a constant 94MB download/upload speed. If I connect my laptop to the ethernet port of the wall I get 850MB download. I have a main router in my house (FritzBox!5590) provided by the ISP, which delivers connectivity to the entire walls, this device is wifi disabled. the Orbi is intended to deliver wifi connectivity. Wires in the walls are CAT6A. each wired port in the house gives me high speed, just wifi from Orbi is slow at 94MB. I already downloaded the update firmware and restarted the Orbi a few times. I’m not a tech guy. Thanks for suggestions.358Views0likes22CommentsWhere has the sort function gone?
I've recently updated my network from an Oribi 750 to a 870. When using the web UI to view the settings for the 750, on the list of connected devices I could sort the view by clicking on any of the headers for the list (see screenshot for example). On the 870 web UI, there seems to be no sort as function on the same page. I found this sort as view option really useful with the 750 system. Is there any way of getting back on the 870 web UI?161Views0likes15CommentsOrbi 870 update issues
So today I set up my new 870 network. Finally got everything working and things were looking great. The wifi backhaul on the 870 is a MAJOR upgrade from the 750 I was on. While I was accessing the router via the web interface it flashed up it needed an update. Never had this on the 750 so always had to do it manually. I clicked the "update all" button and things looked as if they were going ok. However, an hour later, whilst the satellites have come back on and I'm somehow online, the router is still flashing white and I can't access it via the web page or the orbi app. Anyone got any ideas?201Views0likes6Comments
