Crookz's avatar
Crookz
ReadyNas Duo will not factory reset
Hi all,
Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of dsk).
Checking drive in pc, it was never formatted by the unit.
So the next step was to OS restore or factory restore to force a format BUT holding the reset button and powering on device does not result in the 2 disk LEDs coming on (as holding the power button on boot does) and no matter when I release the reset switch 5 - 40 seconds the device just seems to boot normally to return to error state 3.
Its almost as if I'm missing something totally obvious!! As anyone experienced this behavior? Do. Need to return device as switch is broken???
Thanks in advance
ProSupport for Business
