Fishbones's avatar
Feb 05, 2011
Ethernet 1 connecting at 100Mbit only.
After a power cycle on a PRO Business eth0 will only connect at 100Mbit. Swapped cables, inspected and cleaned socket but no go.
The NAS is connected to a GS108T switch.
Log for eth0 after a reconnection shows this:
Feb 5 11:30:13 PRO ifplugd(eth0)[2335]: Program executed successfully.
Feb 5 11:30:26 PRO kernel: eth0: -- INFORMATION --
Feb 5 11:30:26 PRO kernel: Msg: 2 Pair Downshift detected
Feb 5 11:30:26 PRO kernel: eth0: network connection up using port A
Feb 5 11:30:26 PRO kernel: speed: 100
Feb 5 11:30:26 PRO kernel: autonegotiation: yes
Feb 5 11:30:26 PRO kernel: duplex mode: full
Feb 5 11:30:26 PRO kernel: flowctrl: symmetric
Feb 5 11:30:26 PRO kernel: irq moderation: disabled
Feb 5 11:30:26 PRO kernel: tcp offload: enabled
Feb 5 11:30:26 PRO kernel: scatter-gather: enabled
Feb 5 11:30:26 PRO kernel: tx-checksum: enabled
Feb 5 11:30:26 PRO kernel: rx-checksum: enabled
Feb 5 11:30:26 PRO kernel: rx-polling: enabled
Feb 5 11:30:26 PRO kernel: low latency: enabled
Would the "2 pair Downshift" be a configurable parameter? If so, how to reset to 1000Mbit?
Thanks in advance.
ProSupport for Business
