- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBE971 reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBE971 reboots
RBE971 randomly rebooting daily. Sometimes it will reboot and come back on line after 2-3 minutes of disruption - other times the wireless for router & 2 satellites completely shuts off and must be rebooted to restore service.
Looking for suggestions to troubleshoot & fix. Logs do not appear to be capturing whatever is triggering the problem. Is there a way to improve logging to capture what's causing the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBE971 reboots
Firmware v9.12.5.3 was released Dec 26. Might try manually updating to that version and see what happens.
https://kb.netgear.com/000066513/RBE970-RBE971-Firmware-Version-9-12-5-3-for-NA-Region-Only
It is essential to update satellites first and the router last.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBE971 reboots
Upgraded to v9.12.5.3 this morning - will watch & see how this version does - thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBE971 reboots
There was nothing in the Release Notes about this specific problem. However, when people attempt to investigate issues, they commonly want to work with the most recent release and updating firmware is usually the "first step".
In some specific cases, the most recent firmware has been found suspect by members of the forum and the common recommendation is to "go back". With this release coming out so recently and fewer forum members using the 971 platform, you may get to be one of the first to experience it.
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBE971 reboots
Does the front LED on the RBR turn PINK or RED when this happens?
What does the WAN port uptime connection show along with the LAN and Wireless backhaul show on the RBRs web page under the Advanced tab/Show Stats, then compare to the system uptime seen on the RBRs debug page at router IP address/debug.htm? Checking to see if the RBR is fully rebooting here or something on the WAN port is causing a problem.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
