Drekko
Sep 03, 2017Aspirant
JGS516PE - SNMP support? Monitor Temps
hi
Does this switch have SNMP ? I want to be able to monitor its tempretures remotely
It might be possible. Expect that the feature request will be subject for review and assessment.
DaneA
NETGEAR Community Team
- XavierLLNETGEAR Employee Retired
- DrekkoAspirant
Thanks for that info
bit late now, I already bought the JGS516PE
So that is a "unmanaged switch" ?
Is the only way to monitor the tempreture is to log into the device itself?
- DaneANETGEAR Employee Retired
I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility. Also, there is no option to have a console connection to the JGS516PE switch.
DaneA
