esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
Nov 06, 2018Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. This would be effecting wired back haul configurations.
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
OrbiPhilip wrote:
My experience with this firmware is pretty much the same as every version before it. Half-finished, buggy, and unstable. For example:
- Still zero ability to program/tune QOS.
- Wired backhaul connections are still less stable than a $19 switch.
- Satellite booting up while router boots locks up the admin console.
And even with major problems still out in the field, Netgear won't allow owners to open a ticket without paying for extended support. Since I spent $350, I'm going to suffer with it as long as I can. But Orbi will be the last Netgear product I buy.
OrbiPhilip
Nov 06, 2018Luminary
Please do not ignore my post and regurgitate a boilerplate list of questions. You are cluttering up the forum and aren't helping anyone.
- FURRYe38Nov 06, 2018Guru - Experienced User
"Please do not ignore my post" <This is what I'm doing. :smileyvery-happy:
The info seems to be helping others:
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-10-kills-Internet-access-if-you-use-Ethernet-back/m-p/1647536/highlight/true#M42464
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-10-kills-Internet-access-if-you-use-Ethernet-back/m-p/1603922/highlight/true#M35521
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highlight/true#M34020
https://community.netgear.com/t5/Orbi/Backhaul-breaks-the-whole-network/m-p/1615770/highlight/true#M38393https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1586988/highlight/true#M33202
https://community.netgear.com/t5/Orbi/Orbi-wired-backhaul-performance/m-p/1548397/highlight/false#M27862
https://community.netgear.com/t5/Orbi/I-found-a-Connection-issue-Resolution-for-wired-backhaul/m-p/1559747#M29420
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-10-kills-Internet-access-if-you-use-Ethernet-back/m-p/1560805/highlight/false#M29587
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1585890/highlight/true#M33049
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1585994/highlight/true#M33074Disable IGMP on Managed Switch:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123
https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-causing-broadcast-storm/m-p/1641004/highlight/true#M41495
https://community.netgear.com/t5/Orbi/Orbi-RBR50-and-Slow-WiFi-Problems-with-iOS-Devices/m-p/1645981/highlight/true#M42181https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
https://community.netgear.com/t5/Orbi/RBK40-Download-Speed-Slows-Down-After-5-Days/m-p/1643475/highlight/true#M41776
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1553979/highlight/true#M28616
https://community.netgear.com/t5/Orbi/Orbi-Satellite-RBS50-Not-Connecting-via-Ethernet/m-p/1556692/highlight/false#M28949
Roomba: https://community.netgear.com/t5/Orbi/Orbi-amp-the-new-Roomba-i7-connectivity/m-p/1655054/highlight/false#M44045https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1649157/highlight/true#M42960
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1648321/highlight/true#M42695
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1649172/highlight/true#M42966
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1649389/highlight/true#M43029
https://community.netgear.com/t5/Orbi/Your-experience-with-Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1649401/highlight/true#M43034
https://community.netgear.com/t5/Orbi/Your-experience-with-Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1650323/highlight/true#M43206
https://community.netgear.com/t5/Orbi/Satellite-placement-help/m-p/1658715#M44442The info is there for you try. It's not mandatory. It's up to users to try it or not. Not everyone is having a bad time with there Orbis.
Good Luck.
- OrbiPhilipNov 06, 2018Luminary
Not everyone is, but I am. And you aren't doing anything except stroking your ego. Grow up.
No, Im just giving info. Nothing Ego about it. Up to users weather they want to use it or not. Up to you. Just trying to help is all.
Good Luck in your endeavours.
