donawalt's avatar
donawalt
Mentor - Experienced User
Jun 28, 2025
BUG: KERNEL CRASH in 9.13.1.2, Orbi 970
After being up about 28 hours, one of my 970 satellites did a restart. The bug log reports that the reason was a kernel crash.
It was at about 1:30 AM local time, so little or no action going on. The 970 is on a UPS. Here was the debug screen, and I included a link to the debug log zip file in my Dropbox, it was too big to attach; the debug log was run for about 3 minutes, this morning. Let me know if you need more info.
Debug log:
https://www.dropbox.com/scl/fi/3cjd4wkcwyv0bq8imqmx5/debuglog.zip?rlkey=himss1gtw5u0qk77wetafwyz3&dl=0
Straq​
  • donawalt's avatar
    donawalt
    dkarataiev​ did you ever check if you were logging - I had posted for you:
    1. On the router admin web page, Advanced tab, Administration -> Logs: In the section "Include in Logs, turn everything OFF. At the top, click the Clear Log button.
     Then let it run and see if the panics continue.
    Also - did you hear from Netgear Engineering when I posted the info for you how to contact them - any reply, need me to ping them?
    • dkarataiev's avatar
      dkarataiev
      Guide
      I disabled logs a long time ago, and they are still disabled.
      I haven't heard back from either the engineer or the Netgear support.
      Thank you for your help! I appreciate this.
      • donawalt's avatar
        donawalt
        dkarataiev​ I heard back from Fernando the NG engineer:
        Have not had time to respond to this guy, very sorry. Super busy
        Please tell him to send me another email today
        I will make sure to respond tonight
        So can you try again?
  • FYI : The zip files for fw 9.13.2.1 are updated now. Both RBR + RBS zip files are correct on NG side. Please download and upgrade. Try this version. If RBR craches continue, request a RMA from NG.
    • Unfortunately, the new firmware didn't resolve the issue—same problem.
      • FURRYe38's avatar
        Have you factory reset the system and setup from scratch to check this?
        What all do you have connected to 970 series system?
  • Very weird my Satellites updated to version 9.13.2.1 but not my Router...  system works fine though... I'm scared that it might not last long without the Router also being updated to version 9.13.2.1 to match the Satellites.
    • FURRYe38's avatar
      If something happens, you can downgrade the RBS back to same version as what is on the RBR and turn OFF auto update.
      NG is aware of the new FW being posted. There working on it.
  • dkarataiev​
    Most of my issues (especially unexpected router crash  / restarts few times per day) have been resolved after the RMA (replacement) of router (only router, not the Router+ Satellite) .
    With new router and fw 9.13.1.2, I have seen uptime of 60 days! Before the RMA my record was max few days only.
    I suggest that you proceed if RMA, if accepted by Netgear.
     In addition to hardware replacement, fw 9.1.3.1.2 (released in June 2025) also resolved lots of bugs (at least in AP mode). The overall system stability and performance is musch better in my use case, RBR is in AP mode.
    Looking fw to try the new firmware 9.13.2.1 (released Nov 2025) , when NG fix the wrong packaging issue in the zip file...
    • donawalt's avatar
      donawalt
      dkarataiev​ please send an PM, attach a URL as reference to this thread, and add your ticket - to Straq​ . He is a Sr Engineer who has been working with us to diagnose and find solutions to problems users are having. Keep us posted how it goes!
  • donawalt's avatar
    donawalt
    I assume you have 970 Orbi series? Try these steps and wait to see if it fixes the crashes:
    1. 9.13.2.1 is the latest version - https://www.netgear.com/support/download/?model=RBE973S&_ga=2.38375275.974127454.1697786862-475167439.1689166105   Update manually or via the router admin web page (Advanced Tab -> Administration-> Firmware Update
    2. On the router admin web page, Advanced tab, Administration -> Logs: In the section "Include in Logs, turn everything OFF. At the top, click the Clear Log button.
     Then let it run and see if the panics continue. If they do, open a support ticket - get the ticket number and post it here, I'll also send that to our engineering contact who may have some ideas.
      dkarataiev
      Guide
      I also asked ChatGPT with a stacktrace attached, and here's what it said:
      That’s a real kernel panic dump — and it gives a lot of clues about what went wrong inside your Orbi 970.
      Let’s break it down clearly 👇
      🧠 Plain-English Summary
      Your Orbi 970 crashed because a system process (d2d) tried to write to a null pointer (address 00000000) — meaning it attempted to access memory that doesn’t exist.
      This caused the Linux kernel to panic and halt to prevent further damage.
      So in short:
      > A software component in the router firmware hit a programming bug — likely a memory management or networking issue — causing a system crash.
      ⚙️ Technical Details
      From the dump:
      Unable to handle kernel NULL pointer dereference at virtual address 00000000
      Internal error: Oops: 805 [#1] PREEMPT SMP ARM
      Process d2d (pid: 5457)
      PC is at skb_queue_tail+0x1c/0x48
      Crash function: skb_queue_tail() — this is a Linux kernel function that handles network socket buffers.
      Caller: unix_dgram_sendmsg() → part of the inter-process communication (IPC) system using UNIX domain sockets.
      Process: d2d — this is almost certainly “Device-to-Device” communication service used by Orbi mesh nodes to talk to each other.
      Fault: Null pointer dereference → means some buffer or pointer wasn’t properly initialized or got freed prematurely.
      So the D2D (mesh communication) process tried to queue a network packet into a null socket buffer.
      That’s a firmware bug, not a hardware failure.
      🔄 Likely Cause
      This is almost always due to:
      A firmware bug in the D2D or NSS (Qualcomm networking subsystem) code.
      Could be triggered by mesh sync, Wi-Fi backhaul instability, or a corrupted configuration.
      The “Tainted: P” line (Tainted: P) means it’s using proprietary Qualcomm/Netgear kernel modules, so standard Linux debugging is limited.
      dkarataiev
      Guide
      Yes, I have 970. My support ticket is 49350608
      This firmware zip contains the old firmware; they packaged it wrong.
      • McLong's avatar
        McLong
        Luminary
        Yeah, they were running beta firmware. Netgear finally published it into production on Oct 31st 2025 but mistakenly packaged the wrong version. It's really frustrating because the community Mods keep locking down the threads when people bring up the issue.
  • donawalt's avatar
    donawalt
    Thanks Saner​ I was just getting to it when you posted again. I am in touch with Eng on this one actually, plus I do have  support ticket open since yesterday! I'll post here if any progress/milestones are achieved.
    • Saner's avatar
      Saner
      Apprentice
      Most of my issues (especially unexpected router crash  / restarts few times per day) have been resolved after the RMA (replacement) of router (only router, not the Router+ Satellite) , before
      . In addition to hardware replacement, fw 9.1.3.1.2 also resolved lots of bugs (at least in AP mode). The overall system stability and performance is musch better in my use case, RBR is in AP mode.
      Looking fw to try the new firmware 9.13.2.1 , when NG fix the wrong packaging issue in the zip file...
      • donawalt's avatar
        donawalt
        Never heard back. I am on later firmware now, have not had another crash.
  • I have seen your file in dropbox andn opened. I saw below crash evidences.
    I suggest that you create  NG Support ticket and request for escalation to 3rd Level with log file and those evidences :
    bcnss[39]: ERR: Crash shutdown device QCN9224_PCI2 with driver_state 0x107
    bmhi mhi2: CRASHED - [DID:DOMAIN:BUS:SLOT] - 1109:0003:01:00SUBSYSTEM=mhi DEVICE=+mhi:mhi2
      bmhi mhi2: Fatal error received from wcss software!
    cnss[38]: ERR: Crash shutdown device QCN9224_PCI1 with driver_state 0x107
    bmhi mhi1: CRASHED - [DID:DOMAIN:BUS:SLOT] - 1109:0002:01:00SUBSYSTEM=mhi DEVICE=+mhi:mhi1
    bmhi mhi1: Fatal error received from wcss software!
    ar_wal_mlo_ipc.c:2063 Assertion (!g_wal_mac_core_cfg.dbg.force_crash_on_partner_chip_crash_indication
  • Unzip the debuglog and check the content of the file oopsdump.  Search for the strings :
    You should have some evidences with the timestamps
  • FURRYe38's avatar
    Will need to know what you did after FW was updated on the system.
    Updated manually or via AU?
    FW updated and you continued to use the system after the reboot?
    After FW updated, power cycled the system OFF then back ON and continue?
    Factory reset and setup from scratch after FW was updated?
    • FURRYe38's avatar
      Would need some feedback on these questions:
      • donawalt's avatar
        donawalt
        Updated manually or via AU? Manually
        FW updated and you continued to use the system after the reboot? Reboot from update, then PC everything
        After FW updated, power cycled the system OFF then back ON and continue? Yes
        Factory reset and setup from scratch after FW was updated? No
