Vivienne
Sep 06, 2015Follower
N450 WiFi keeps disconnecting
Hello,
So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the WiFi keeps disconnecting to any devices relying on it such as cell phones, ipads, roku etc. There will be times when I'll search for the WiFi network, and ours won't even show up. I've pretty much had to reset the router everyday and it just seems to be getting worse.
I've tried contacting Netgear but because my item is over 90 days, they pretty much said google it and hope you find the answer. I've tried contacting squaretrade, where I got my warrenty, and they just took me back to Netgear.
If anyone has had this problem, what did you do to fix it? It would be greatly appreciated.
- TeacherLadyAspirant
I just hooked mine up, and Comcast shows it's working fine. But it keeps kicking us off wireless. Anyone have a fix for this??
- DarrenMSr. NETGEAR Moderator
Have you guys tried changing the wireless channel something could be causing interference with the signal such as neighbors routers, home appliances, or cordless phones.
DarrenM
I tried EVERYTHING. I finally got the NetGear tech to throw up his hands and say the unit might be malfunctioning. Took it back to the store this morning, got a different NetGear model, and hooked it up with no problems! :smileyvery-happy:
- jacwa01Aspirant
I too am having the same problem: my laptop (Windows 8.1), and my daughter's Macbook and Apple TV experience loss of access to our home network at various times of day. I am forced to turn Wireless off/on, forget the network, and/or run troubleshooting diagnostics.
NETGEAR support had me change Channel from 1 to 11, and things seemed to work for a while, but now the disconnects are back. I have gone to the admin site and checked the power levels and signal-to-noise ratio for upstream/downstream power and they appear to be well within spec.
Anybody have any new ideas??
- amitshah28Aspirant
I have the same issue...on the hardwire the N450 works super fast but on wireless its super slow ..had comacast guys check for 3 hrs all connection , software etc..from their end the signal is good ..looks like an issue to n450 for wireless connection on comcast
- DexterJBNETGEAR Moderator
Hi amitshah28,
1. Does the issue happen on all of your devices?
2. Have you tried changing the wireless channel?
3. Does the issue happen whether the devices are close or far from the N450?
Dexter
Community Team
- jthuAspirant
Same issue here as well. Talked to the customer service rep; he wants me to pay $89 or so for the additional tech support to try out settings, etc. I believe this is a bug introduced in the latest version of the firmware and has to be fixed with an update to the firmware.
- wirelessloveAspirant
I have the same issue. i called customer service for 1 hour and only they asked me to pay 110 $ for warranty extend. i tried to get hints to resolve issue from customer representive but no luck. i can buy another one with 110 $. i belive it is bug with FW and i am not sure which latest FW to upgrad. any help ?
- jthuAspirant
I don't believe they have come up with an upgraded firmware to fix it. Meanwhile, they may downgrade the firmware to solve the issue provided we pay whatever they are asking to pay. Nice way to make more money. For now, I am just re-booting the router every now and then to keep connected.
- rmctoddAspirant
I faced this problem several months ago and I used a different router with this modem. Now I'm trying to debug this and I find the same issues described here.
- The wifi connection dies on almost all devices
- The wired connection is fine
- On changing the wifi channel (after connecting using wire), the wifi works for some time and usually within a few hours, it is down again.
Does netgear have a solution or a firmware upgrade planned? Will comcast deploy it?
I'm using the latest firmware version: 3.01.06
I've been using this for 2 years now (although I've had this problem for several months). I'm pretty disappointed that this hasn't been solved even though many people are reporting this issue.
- bakingsodaAspirant
What is the second router you use to test with?
I'm also having the same issue with my N450 with Time Warner. Only started noticing the issue recently. On TWC's site (Should I Lease or Buy a Modem page -> Download speeds up to 100Mbps section), the N450 is grayed out and listed as an "Internet Modem Only". TWC is probably trying to force us to an upgrade and make it seem like there is an issue with our hardware. Obviously this is not just an "Internet Modem Only".
https://www.timewarnercable.com/en/support/internet/topics/lease-or-buy-modem.html
- rmctoddAspirant
Hi:
I used a Linksys WRT54G router which is an old router.
I should add that this one was working well for a year and I suspect that a firmware upgrade ruined it. This is not just a modem.
- tomlyuAspirantHi Darren,
Thanks for replying.
I checked the link in your post, it suggests that the firmware version for my N450 should be v1.00.05 but the actual version is v3.01.06
Do you mean Netgear gave a wrong baseline firmware to TWC or TWC pushed out a wrong version of firmware? Hello,
This issue is happening to me too, have N450 and I'm a TWC customer
This is affecting all conectivity in the modem (wired and wifi).
This happend after someone (TWC or Netgear) pushed firmware 3.01.06
and it started about 10 days ago
Try to reset the modem and initiate a constant ping 'ping XXX.XXX.XXX.XXX -t'
After reset you should see regular latency numbers, as time goes by you will notice
that every 16 packet, the latency is much higher, if you leave the modem without restarting
for more then a day you might see 3000+ ms latency for something that is usually 30+ ms
Here is a constant ping to one of the servers (about 8 hours after restarting the modem) :
Reply from 24.93.40.116: bytes=32 time=31ms TTL=247
Reply from 24.93.40.116: bytes=32 time=46ms TTL=247
Reply from 24.93.40.116: bytes=32 time=29ms TTL=247
Reply from 24.93.40.116: bytes=32 time=23ms TTL=247
Reply from 24.93.40.116: bytes=32 time=20ms TTL=247
Reply from 24.93.40.116: bytes=32 time=69ms TTL=247
Reply from 24.93.40.116: bytes=32 time=45ms TTL=247
Reply from 24.93.40.116: bytes=32 time=32ms TTL=247
Reply from 24.93.40.116: bytes=32 time=24ms TTL=247
Reply from 24.93.40.116: bytes=32 time=56ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1361ms TTL=247
Reply from 24.93.40.116: bytes=32 time=26ms TTL=247
Reply from 24.93.40.116: bytes=32 time=22ms TTL=247
Reply from 24.93.40.116: bytes=32 time=21ms TTL=247
Reply from 24.93.40.116: bytes=32 time=19ms TTL=247
Reply from 24.93.40.116: bytes=32 time=25ms TTL=247
Reply from 24.93.40.116: bytes=32 time=40ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1293ms TTL=247
Reply from 24.93.40.116: bytes=32 time=43ms TTL=247
Reply from 24.93.40.116: bytes=32 time=42ms TTL=247
Reply from 24.93.40.116: bytes=32 time=38ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1304ms TTL=247
Reply from 24.93.40.116: bytes=32 time=52ms TTL=247
Reply from 24.93.40.116: bytes=32 time=17ms TTL=247
Reply from 24.93.40.116: bytes=32 time=44ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1386ms TTL=247
Reply from 24.93.40.116: bytes=32 time=94ms TTL=247
Reply from 24.93.40.116: bytes=32 time=62ms TTL=247
Reply from 24.93.40.116: bytes=32 time=27ms TTL=247
Reply from 24.93.40.116: bytes=32 time=18ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1570ms TTL=247
Reply from 24.93.40.116: bytes=32 time=75ms TTL=247
Reply from 24.93.40.116: bytes=32 time=51ms TTL=247
Reply from 24.93.40.116: bytes=32 time=36ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1383ms TTL=247
Reply from 24.93.40.116: bytes=32 time=28ms TTL=247
Reply from 24.93.40.116: bytes=32 time=41ms TTL=247
Reply from 24.93.40.116: bytes=32 time=30ms TTL=247
Reply from 24.93.40.116: bytes=32 time=70ms TTL=247
Reply from 24.93.40.116: bytes=32 time=1562ms TTL=247
Reply from 24.93.40.116: bytes=32 time=19ms TTL=247EXACTLY every 16 packets there is a much bigger latency.
Smells like a software issue.
I started seeing messages about this at the end of last month, probably someone initiated
this push, but I see that this issue has been going on for months from the posts here.
TWC says they don't push firmware updates to customer modems, and Netgear says
only TWC can push the firmware
TWC and NETGEAR - stop blaiming each other, take responsibility and fix this issue !!!
Folks, I suggest that if you want this resolved, start making noise in both companies.
- tomlyuAspirant
Totally agree with you, we need to make more noise to be heard...
Btw, here is the so called "tier 3" tech support number of TWC: 718-358-0900
One of their excuse was: if we pushed out wrong firmware we should have seen many complaints now...
- aniorangeAspirant
I came here looking for help because I have had the same issue. We have had the N450 just over a year and it worked fine until about a month ago. Then the wireless started becoming a problem. Computers were connected but had no internet and the only solution was to restart the N450. This happeded every few days. The past 3 days, the speed has been horrible. The disconects are getting worse. I see that this is a issue for many others and the blame is being tossed around. I chose Netgear because I have been satisfied with Netgear products in the past, but it looks like it's time to abandon Netagear and look elsewhere. One of my roomates works from home and this just will not do. We need a solution.
craigwf - from what I read you're on Comcast,is that correct ?
Also, from other responses about this issue, I understnd that the ISP's have ccess to the firmware source code,
I thought that maybe TWC has some bug, but if this is happening also with Comcast,
then I suspect the bug is in the Netgear code.
I just can't beleive that Netgear has avoided this issue for months, and now that TWC has pushed the faulty vrsion
(althoguh they will not admit it), they also, have to be responsible for fixing this.
THIS IS A NETGEAR FORUM, WHEE IS THE NETGEAR REPRESANTATIVE ????
PLEASE ADVISE AS TO WHAT IS DONE ABOUT THIS SERIOUS ISSUE
- aniorangeAspirant
I neglected to mention I am also a TWC subscriber. I am thinking that perhaps I should pick up a seperate modem and router, that way any firmware upgrades do not impat the wireless protion. I am also thinking of puchasing one that I know they use. Before I moved I rented a Surfboard modem router combo that worked great except for the occasional hiccup. It would occasional drop signal but right itself after a minute. The Netgear has to be unplugged.
- aniorangeAspirant
I should also add that we have one computer hooked in directly. It can still connect when these issues occur, but it slows down.
- I'm also having this problem - it started when TWC Pushed the firmware to v3
Wifi appears to "lock" daily - it gets slow then fails to operate. The v1 firmware worked without issue.- rakstempAspirant
Just adding to the forum, having the same issue...
WHERE ARE THE NETGEAR REPS THERE HAVE BEEN NO ANSWERS!!!
I really feel netgear is just avoiding the issue..
I'm postive there are tons of customer with the same issue that just have not posted to the fourm..
- player1Aspirant
I have the exact same problem! Just made an account so I can reply here.. Ping jumps on all my devices also internet gets slower the longer my router is turned on. Turning it on and off solves all these problems until 1-2 hours later i start noticing it getting slower again. After 1 day I usually cant even use it anymore(250mbps download speed goes down to 1mbps...).
Guess I have to get a new router.
Has any of the folks here contacted TWC or Netgear and managed to make some progress ?
Also, I see that it is not recommended to buy a device that is both modem and router as the N450,
any one has any advice which modems and routers might be decent replacments (of course not Netgear) ?
Yeah, I think I've learned my lesson on this one. Between TWC / Spectrum and Netgear, I don't expect this to be resolved in any reasonable time -- even if Netgear has a fix, they'll have to convince TWC to implement and push it.
Why the wireless firmware wasn't decoupled from the cable modem in this package is beyond me.
I'll see if I can just disable the wireless on this and buy a separate access point for the wireless. At least the switch and cable modem in this aren't broken (yet).
Invalidation - are you saying that if we disable the wifi, the latency issue will not happen ?
Also, has anyone got a phone number to the netgear tech support ?
No, I'm saying, at least on mine, the latency issue is only affecting wifi. Wired is continuing to operate at full speed, even after wifi has fully failed.
I *just* read someone saying otherwise in another thread, so I don't know if this is normal or not.
