Vivienne's avatar
Vivienne
Follower
Sep 05, 2015
N450 WiFi keeps disconnecting
Hello,
So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the WiFi keeps disconnecting to any devices relying on it such as cell phones, ipads, roku etc. There will be times when I'll search for the WiFi network, and ours won't even show up. I've pretty much had to reset the router everyday and it just seems to be getting worse.
I've tried contacting Netgear but because my item is over 90 days, they pretty much said google it and hope you find the answer. I've tried contacting squaretrade, where I got my warrenty, and they just took me back to Netgear.
If anyone has had this problem, what did you do to fix it? It would be greatly appreciated.
