- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-...
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 drops internet
Next time the issue occurs can you reboot the modem please, if it works after that first time then it could indicate a negotiation issue between the two.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Give static IPs to your consoles, do they still drop then? If not then that narrows it down quite a lot. Either way we are definitely aware of the issue and are debugging as we speak.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can confirm this is happening ALOT on my XR500. Constantly dropping the internet, all devices connected, (either wired or wireless) will lose internet connection. Reboot and it stays stable for a while, but problem re-occurs and starts to re-occur more frequently. It's not just while gaming either. Just while I was typing this I lost internet and it came back.
I'm on PC, but like I said it doesn't matter what device(s) you are using.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No mate, don't have an Xbox One. I do have Windows 10, 1803, but I have removed all Xbox apps from there, GAME DVR is disabled, etc. Also my wife has been using her work laptop to work from home all day, and they definitely don't have any Xbox apps on there and it's been terrible for her.
So far I have set anti-buffer bloat to NEVER = random disconnects
Disable Port Scan and DoS Protection (enabled) = random disconnects
I've now turned off QoS totally and am testing that. If that fails then I will turn off UPnP.
Basically trying to go through things one by one to see if I can locate what is causing this. But obviously turning off some of these settings isn't ideal as you are disabling features that are the very reason for you purchasing the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should be able to keep the same Geo-Filter settings if your radius is wide enough. I don't foresee a possible way where you could not change the Geo-Filter depending on the game you're playing. It is more of an interactive router compared to other routers in the past that are more plug and play but that is why it gives you such a huge benefit over the other routers - customisation is key.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After reading the thread, I would like to know what firmware I can use to correct the same issue. We have a mix of Windows 10 computers, Macs, XBox, Apple TV, and Amazon Alexa's in our house. Our internet drops constantly - while stating that we are still connected to the network. It can sometimes be fixed by rebooting the netgear modem, but it is happening more and more often. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi can I also have this firmware? my XR500 keeps losing internet connection which makes me think it's not communicating properly with the the VDSL modem as I can tell the modem is not going down at all. Has netgear identified what is causing this yet?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Fraser,
I'm having the same issues with my router randomly losing connection with my modem as well. A restart usually fixes it.
Any possible way I could get the firmware too?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
10 | |
9 | |
6 | |
5 | |
2 |
