- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue as a lot of people here. Random internet drop outs. Atleast once a day sometimes 2-3. A reset of the router fixes the issue...temporarily. Have the most recent firmware installed 2.3.2.32.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there newer then V2.3.2.32-802-3-az-1009 now ? I was thinking about buying the xr700 till i saw people are complaing about the same problems on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a more recent beta to try for the XR500?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was wondering the same Its so weird like my net is not dropping out on streaming movies and what not but on 3 different computers and ipad websites dropout. I see a ton of lease changes and renewals in my logs like every 30 minutes or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
under geo filter next to km away there is a profile button click it and destiny is in the list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think it just makes a diffrent search area
- Mark as New
- Bookmark
- Subscribe
- Permalink
Smith sent you a PM with that firmware.
Casteel, as above just changes radius and for Destiny disables strict mode. Don't need to use a profile to play a game, just gives our recommended radius
- Mark as New
- Bookmark
- Subscribe
- Permalink
alright, Thank you I am still having problems i have restored and reflashed firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After trying the beta firmware XR500 V2.3.2.32-802-3-az-1009 over the weekend, the issue persists @Netduma-Fraser . ~Once per evening, usually during our heavier usage time, we lose iternet connectivity with no change to online status of router nor modem. A reboot resolves the issue but only for another day or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Bob - sorry to hear it is continuing. There should hopefully be a new build soon. Have you been able to raise a Case ID with NETGEAR? If not, I recommend you do this as they might be able to send you another beta firmware to help with your problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been having this exact issue since I purchased the XR500 and the newest firmware release only made the lose of internet functions happen more often.
I have my XR500 router conected to a ARRIS CM3200A modem. When the internet stops working through the router, I can plug my devices directly into the modem and see that the ISP and modem are functioning as intended, as far as I can tell.
The issue seems to be heavily or entirely releated to my XBox One X. I have noticed the hard disk spinning up to download and install updates at the same moment the XR500 stops serving my devices. It does not disconnect, reset or crash. I can log into the router via 192.168.1.1 and nothing looks out of the ordinairy in the logs.
I turned off auto updates and put the power option on my XBox One X (connected via LAN) and my XBox One S (connected through wifi) to power saving mode. This did not stop the issue.
Tonight I installed Hitman 2 and related DLCs onto my XBox One X. During the installion from DISC it also downloaded large files. The XR500 disconnected within 10 minutes over and over again. I unplugged the CAT7 cable from the XBox One X and set-up a wifi connection. I still lost internet functionality on all other decives, wifi and LAN, within moments. This was while the XBox One X was powered on, not off/asleep.
I turned my power option back to Instant on mode and let the game install while powered down. I did not pay attention to if the disconnects continued, but instead watched a Blu-Ray. Considering that quit a few hours my game is still not installed, I have to assume time was wasted sitting idle, waiting on the router to bring itself back online.
The only "fix" for this issue is to turn the power off and then back on again and wait for the router to reboot. This isn't what I was expecting when I replaced my functional, but underpowered sub-$100 DD-WRT router I had used for six years without issue with a $300.00 "premium" device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Serpent - that's a serious problem you're having there, sorry to hear it. I recommend you contact NETGEAR's official support asap to see if they can give you steps to fix or possibly replace the unit: https://www.netgear.com/support/contact.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
so after many many months of headaches I have hoocked up a diffrent router, all my problems are gone now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my case, it appears to be a combination of this XR500 and the comcast XB6 cable modem.
While running with this for months, I lived with router reboots a couple times a week. No change after the beta firmware.
Then I saw all the talk about Puma issues. First I moved to my back up Uverse with no reboots for over a week.
Then I swapped my rented comcast XB6 for an XB6-T that has broadcom, and put that back in front of the router, and again no reboots for several days.
I'm not saying another router doesn't handle the Puma issues better...all I am saying is that first make sure you have a modem with a Broadcom chipset if you really want to stick with this router for its gaming features not found elsewhere. The combo of XR500 + Puma were the cause of my troubles.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I my modem is a sb8200 its not a puma 6 chip.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry to hear. I like the gaming features enough from this XR500 to have dealt with this, but really miss the dual wan features of the asus RT-AC87 that I moved away from. I've found with the XR500 it does upnp for multiple consoles and provides open nat consistently like no other. also the geo filter stuff to avoid gambit or crucible matches in high latency lobbies it worth it for me. If not for these, i would have swapped the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now I’m resetting it everyday. My home cameras are always out when I most need it due y this router. It’s miserable.
Please help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently installed a home camera and was woken up at 1:30 AM due to a loss of video alarm. I have the camera set to record continuously, but when I checked Device Manager in the XR500's firmware UI after logging into the router immediately following the alarm, it indicated the camera was offline. Based on what I've seen in the XR500 System Information Logs, the router appears to be undergoing DHCP lease renewals at fixed intervals (24 hours?), whereupon the camera lease is not renewed (maybe due to the camera not accepting a refreshed/different IP address upon renewal, or otherwise getting confused?). The system info log was filled with DHCP lease renewal events immediately preceding the loss of video alarm; however, the camera lease was not renewed, unlike every other pre-alarm-connected device.
Other routers I've worked with had a UI option to extend the DHCP lease time, but I can see no such option in the XR500's UI. Hopefully a firmware fix is in the works as this is a helpful feature. In the meantime, I've assigned the camera's MAC a reserved IP address near the top of the allowed range via Settings -> Lan Setup -> Address Reservation as well as upping the amount of time it takes for an alarm to trigger, per the camera's software settings, to give the lease time to renew without alarm. Will post back here if this does, or does not, work.
