- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Samsung Galaxy S8 not working on Orbi RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M internet connection in Hong Kong with maximum speed around 450-550M in my other router - ASUS RT-AC68U. This Orbi only runs around 250M something. I'm very disappointed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Samsung Galaxy S8 not working on Orbi RBR40
On the S8, i would try deleting the wifi connction info and re-enter for for orbi system..
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm having the same issue since the most recent orbi firmware update. I've done everything from forgeting my wifi on my S8, factory resetting my orbi, to factory reseting my Galaxy S8. All my other devices work fine on my network. I thought it was the phone, but it works fine on other wifi networks. The only solutio i found was to connect my Galaxy S8 to the guest network. That seems to work form me which is weird. The problem could be a combination of the Galaxy s8 and the orbi router...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Our support team would like to work with you on these issues with the S8 if you would like to work with them send me a PM with your name, email, and phone number.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have exactly the same issue with my Samsung Galaxy S8+ phone and Orbi RBR50 with the latest firmware (V1.12.0.18) installed on the router and the satellite (RBS50). It started very recently I am not sure when exactly but probably after one of the latest phone updates. There were multiple phone updates just recently including updates for Bixby and I am not sure if any of them triggered the issue. I called Samsung and they asked me to reset the phone reset the routers and all possible resets including to try the Safe mode but nothing helped. I don't have any wireless connection issues using different wireless routers such as at work or when visiting friends so it must be something specific to Orbi. Also, I noticed that when disabling SSID Broadcast for 5GHz the issue seems to be less severe as the phone gets disconnected less often.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
We are aware of the issues and working on them I know one person said S8 works just fine on the guest network.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The disconnecting issue started for me right before the latest update. Also I cannot get my 5Ghz band back on or none of my devices will connect to it. I haven't touched any of the settings since I updated to the latest firmware and did a factory reset. All my devices don't disconnect that often but I've seen my Samsung tablet disconnect at least once. My desktop connected to the satellite via RJ45 has disconnected once too. It's just my S8+ disconnecting constantly. I also noticed when I stream on my Samsung TV there are stutters and I have a 1gbps fiber optic Internet. I get max speed of 600+mbps because currently I'm using the cheap CAT5 wire that was used as a telephone line that I converted to RJ45s because the wires are glued and it's a hassle to rewire them. Before the software update everything streamed very smoothly but it's bareable since it's like 10 seconds at most.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Another thing I notice is that my WiFi strength used to be no less than -50s on 2.4Ghz since my 5Ghz won't work anymore, now it goes as low as low -70s from about 20 feet away in another room.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I downgraded my firmware to V1.10.1.2 because that was the last firmware that didn't give me any issue. I remember 1.11 got me disconnected. Then I followed https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5 to disable auto update.
Now my router and satellite works! My 5Ghz band connects and my S8+ doesn't disconnect anymore. None of my devices are having any issues so far. I have an Xbox One, PS4, August Doorbell Cam, Chromecast Utlra, 2 iPhone 6+, iPhone 7, 2 Samsung S8, Macbook Pro 15'' mid 2015, and a custom Desktop connected to the satellite via RJ45.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The problem is, my wife has an iPhone, which disconnects on that version. It would be really NEAT if Netgear could release a firmware that WORKED with several different devices at the same time. I'm about to sell my Orbis on eBay and/or burn them in the back yard. I paid way too much for this to always be waiting for a new firmware or beta to fix a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The issue is clearly the Orbi. Constant disconnection for S8/S8+ is not the only issue. My 5Ghz radio doesn't work anymore. I factory reset my Orbi router, satellite and my S8+. None of them works. Rolling back to an older firmware fixed most of the issue but there are people in my household that have an iPhone. So I rolled back and tried the guest account. That worked for me!
S8 and S8+ owners. Try creating a guest network and connect your phone there. My phone hasn't disconnected the past 2 or 3 days.
Anyone else not able to connect to the 5Ghz radio? I disconnected and reconnected and used my phone in front of my router and satellite but I can never connect to the 5Ghz. None of NY devices can connect to it. I factory resetted at least 2 times and still no luck. I can only connect to it if I roll back my firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
We are investigating the issues with the S8. will let you know when I have a update or a fix but right now the work around is to connect it to the guest network many customer have reported that to work.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am having the same issue. All devices work fine except the Glaaxy s8 Plus. Connects and disconnects all the time. I get the wifi signal on the phone with the exclamation point thru it. The S8 works everywhere except on this Orbi. Hard to believe that its not an easy fix on Netgears end. I will try the guest account, hoping it will do the trick for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Add Surface Book to the list of devices having trouble staying connected. My main latop, an I7 Surface Book, now disconnects every 5 minutes or so. SO that is really neat.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I discovered the same thing by connecting to the guest network, but my sonos is connected to my home network. Such a pain. When is the patch coming out to address this with the s8 phone???
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have the same issue with my s8 plus. This happens after verizon update yesterday. Can netgear takes a look at this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So I added a guest network and now my galaxy s8 plus appears to be working and not disconnecting. Seems like this is a work around until it gets patched.
