Orbi WiFi 7 RBE973
Reply
Feedback for R7000 New firmware 1.0.9.18
bascaves
Apprentice
Re: Feedback for R7000 New firmware 1.0.9.18
Hello,
As I posted earlier I am still on V1.0.9.6_1.2.19. Which for me was the first release after many brought some basic stablity. This without turning on.
1. Guest network
2. QoS
3. DMZ
4. VPN
Hence not a single feature you would expect useful from a modern SOHO router.
Netgear as many other companies are very geared to the US market, forgetting that many other users outside this market don't need features like Disney Circlel  That even would break things. Also the NSA steered and sponsored data-collection that Netgear as US company does probably breaks things and isn't really appriciated by the rest of the world.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 501 of 897
decalpha
Guide
2.4 band has internet connectivity with 1.0.9.12_1.2.23.
Will post back after couple of days.
Message 502 of 897
dabl
Initiate
@Diggie3 wrote:
Not pointing the finger at the last post specifically, but I think we should not talk about stability until we have 48 hours under our belts. All that happens is someone posts "1.0.9.x seems stable" and then again the next day with "nope, turns out it wasn't!".
Yep, and I'd argue even longer in some cases.
In my case I was able to mitigate client wireless disconnects by rebooting the router, a solution which lasted only 12 to 24 hours.  Disabling the guest network (which also reboots the router) lasted 7 days for me.  When disconnects started happening again I used the previously posted shortcut of clicking "Apply" under "Wireless Setup" of the "Netgear Genie" router setup screen which caused my clients to re-connect again successfully. I saw drops within 12 hours of that action though so I wonder if a full reboot can cause the workaround to last longer.  I have an 2014 R7000 running the V1.0.9.14_1.2.25 firmware which is the update where I believe the client wireless disconnect problems started for me.  Previously everything had been running fine using 1.0.9.12 so I'm considering going back to that firmware revision or possibly trying Xwrt-Vortex if I don't see a fixed firmware from Netgear soon.
Message 503 of 897
Ericsson
I switched to Xwrt-Vortex
Model: R6800|Nighthawk AC1900 Smart WiFi Router
Message 504 of 897
ryanvellia
For those switching to Xwrt-Vortex does it mitigate the 2.4ghz band issues? Is it easy to install the new firmware? I am by no means a networking expert, just trying to maintain my home office. Someone technical (built my computer, setup home network) but limited in some ways.
Message 505 of 897
Djzgfx
Tutor
Yes and yes it’s really easy.
Message 506 of 897
ryanvellia
So how do I go about flashing the new firmware once I download it from the website? Can I do it from my routerlogin.net page?
Message 507 of 897
vincentw56
Tutor
Flash it like any other firmware. It takes longer to boot up. After that, you can enjoy the stability that this router should have had all along.
Message 508 of 897
ryanvellia
Like I said I'm limited as far as routers go, I've never flashed firmware before.
Message 509 of 897
Ouin
Tutor
Be careful that Xwrt-Vortex is not an open source firmware and we download only a compile version. We should thrust a Russia site and be sure that there are no spy process inside!
Message 510 of 897
vincentw56
Tutor
Because ALL Russians are bad.
Message 511 of 897
shamarin
Virtuoso
Thank you! This is a compliment for me and for all people in my country.
Message 512 of 897
rogier64
Luminary
I'm scared for American Netgear for build in NSA backdoors 🙂
Message 513 of 897
BradR7000
Star
What does Xwrt-Vortex have that Advanced Tomato does not?
Message 514 of 897
rogier64
Luminary
Advanced Tomato has more options than XWRT-Vortex. More options doesn't mean better, in most cases you do not want to touch the features because you can screw up a lot. XWRT-Vortex for R7000 is a port or XWRT-Merlin which is based on the Asus firmware (based on Tomato). As XWRT-Vortex uses the HW-acceleration drivers (just as NG does) it has no limitations in WAN to LAN speed like most of alternative firmware do have.
Message 515 of 897
rogier64
Luminary
@dnbas wrote:
Going back doesn't help.
I went back to firmware 1.0.5.70_1.1.91 from 1 year ago and problems stays.
Now for 2 days on XWRT-VORTEX and seems oke now.
That's exactly my experience. It looks like something is screwed up after a certain FW upgrade. Going back to older FW doesn't solve it. I run XWRT-Vortex for about 8 months now, definitely won't go back to NG FW.
Message 516 of 897
AlpineKid66
Guide
I hope it works for me.
Message 517 of 897
rogier64
Luminary
I'm sure it will 🙂
Message 518 of 897
rogier64
Luminary
Betreff: Feedback for R7000 New firmware 1.0.9.18
@ryanvellia wrote:
I'm having the same 2.4g/5g problems others are. 5g seems to work fine with most devices but nothing can obtain an IP address on the 2.4g band. This has been happening for some time now and none of the firmware updates seems to fix the issue. I'm running V1.0.9.18_1.2.27 right now.
We shouldn't have to run 3rd party software for the router to do what it's intended to. I know I'll never be purchasing a Netgear router again after this disaster.
I'm quite happy with my R7000, the hardware is fine although somewhat outdated now, but it still does the job well. The firmware however is buggy and luckily there are plenty of alternatives.
Message 519 of 897
Crozzaa
 When downloading the "XWRT-Vortex" file, there is 2 files instead the folder, a .CHK and .TRX , which file to i use?
Message 520 of 897
rogier64
Luminary
If you're flashing from a Netgear firmware you have to use the .chk file. If you are on XWRT-Vortex firmware you must use the .trx file. Please be aware that you will get a warning that the firmware is older than installed now. Ignore that message and proceed with flashing. Also booting takes a longer time. Just sit down, relax and wait for complete boot.
Message 521 of 897
dnbas
What rogier64 writes is correct, I only had problems with the logging of the router after loading this FW. I didn't get in because username and password where gone. After 2x reset of the router and several tries I got the setup wizard. After that it was a piece of cake.
Message 522 of 897
Crozzaa
Cheers for the help, Can you please tell me if "Nat Filtering" is on the firmware?
Message 523 of 897
rogier64
Luminary
Before going into detail, there is a lot of info on http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
Message 524 of 897
Rikardo007
Tutor
So to confirm, if I am flashing from stock Netgear firmware, I only need to load the .chk file?
I found this tutorial (http://avi.im/blag/2015/asus-wrt-merlin-on-netgear-r7000/) posted in another thread which says you do the .chk to get Tomato then the .trx to get XWRT-Vortex.
Message 525 of 897
Top Contributors
Announcements
Orbi WiFi 7
