NETGEAR Home and Mobile content has changed location. You can find troubleshooting, questions and support resources at https://www.netgear.com/support/home/
roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles, but that did no good.
Any help connecting to the router would be appreciated.
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
- JroachLuminary
I am also experiencing this symptom. Internet woks but can't access admin via URL or Orbi app on IOS. Power cycle, different browsers, nothing.
Were our orbi's hacked?
- RyrxTutor
Same here, trying to give access to a new device and cannot access the Orbi router. Tried power cycling the router. Have tried both wireless connections and wired connections.
The browser states: XXX.XXX.XXX.XXX refused to connect. ERR_CONNECTION_REFUSED (Using an wired ethernet connection)
The app states: We can't find your Orbi. You may be connected to another router or access point. (using wireless connection).
All of the devices still have internet access, so the router is still working, just won't allow connections to the controls.
- I have done a quick reddit search and this seems to be an issue that popped up after a recent firmware update. Only solution I saw was to reset the modem.... if anyone else finds a better solution please let me know.
- JroachLuminary
I reset the modem and still have the issue.
- dbnortonTutor
This really sucks!! I would love to know how many others are having the same issue!! I would love to know how long I haven't been able to access my admin page of my router!! I am really not wanting to do a factory reset on my router but It looks like I may have too! I have a lot of static IP's that I will have to set back up!
- Dbnorton, I have several devices and applications dependent on static IPs. I had to go through and change all of my references for all the ips that changed and make static/reserved again.
I was surprised that a lot of my devices did come back back with the same IPs. - JroachLuminaryAgree. Netgear seem to think that this is acceptable.
I'm also having this issue. I've gone through the factory reset and it has changed nothing except for the fact now my wifi settings are gone and my wireless devices are offline. I've removed the app from the phone and tried settings it up from scratch that way and it still refuses to detect that the orbi even exists to be able to run through the initial setup..... connect it to my desktop via hardline, still can't reach 192.168.1.1 or 10.0.0.1.
I now have a very expensive unconfigurable, unmanageable wireless router, thanks netgear!
What Orbi models do you all have?
NG is aware of users having problems with Orbi AX systems and orbi app having problems over this past weekend.
Any of your systems recently updated?
What version of FW if you get this information.
Some users have done a factory reset on the RBR and setup from scratch using a wired PC and web browser connecting with HTTP and 192.168.1.1 or orbilogin.com. If you do this, disconnect the RBR from the ISP modem/ONT temporarily to see if you can get the setup wizard started on the RBR in a web browser.
I was using the RBR850 AX6000 model.
Other then a firmware update that I manually checked for and ran 6 months ago I did not recently run any updates myself, and had no problems accessing the login page in those 6 months.
I can check the FW version it's currently running after the factory reset when I get home tonight but was unable to get into the router while it was locking me out to see.
As you stated I factory reset mine twice with no success, I had success on the third time around and I think I may have left the WAN connection unplugged at that point. Which is where I was finally able to reach the login page and run through the setup again.- FURRYe38Guru - Experienced User
Thanks for letting us know that worked for you.
- webminsterLuminary
But seriously - this is insane. They know. And they didn't pull the update. That basically implies they don't care.
I have an RBK752. Not sure why I bought this as a replacement for my previous Orbi set. I have the same issues, but I haven't had enough time to have to reinstall the whole thing.
FURRYe38 wrote:What Orbi models do you all have?
- RyrxTutor
I may have missed this reading through all the various posts here and other places, but before I start the factory reset path I'd like to know if anyone can answer these questions:
1) Assuming the factory reset worked, what firmware version is now running on your router? Did it update to the most recent version that is causing the issue (we think) or is it an older firmware version? (Yes, I know the factory reset would return it to an older version, just not sure how much it would update as the setup progressed).
2) If it reset and is running correctly using older firmware, has anyone had the new firmware push to their router a second time and cause the issue to return?
3) If the only issue a person is experiencing is a loss of the ability to communicate with the router for settings and such, using either the app or direct connection, is there a concern for allowing the router/satellites to continue to provide network service? What's the thought on the security of the info going through the router?
I'm not really concerned about Q3, to be honest, but it is a possible concern. But I would like to know about Q1 and Q2 before I spend a few hours redoing everything just to have the firmware update return and put the router right back where it is.
Thanks for any info.
"[Initialized, firmware version: V4.6.8.2_2.1.9] Monday, May 09,2022 00:37:38"
that is the start of the log on my router at 12:37 am this morning after I was successful in the third factory reset after leaving the WAN disconnected.
V4.6.8.2 is the latest release that was put out on 04/27/2022. So no doing the factory reset does not appear to revert firmware updates.This was auto pushed to the routers as there appears to be no option in the web GUI to disable auto updates of the firmware. The only way I've seen to disable those requires you to enable telnet and hard change it there through configuration values. (This push appears to have happened somewhere over the course of Saturday/Sunday as this is when people noticed their routers restarting. and the mass complaints of this started pouring in)
Prior to this auto push this was already a known issues as you can see the release documented on reddit here.
https://www.reddit.com/r/orbi/comments/udbpy5/new_rbr850_rbs850_firmware_version_4682_released/
In the first few posts of this release you can see that people who willing installed this FW update were already experiencing the same issues of becoming unable to reach the management page. How or why this was forcefully pushed with that kind of feed back is beyond me........
- what_the_deuceInitiateI have the same problem. Cannot access management page or access parental control either. Orbi app isn't working either.
I'm NOT about to reset the router and spend hours setting it up again.
Netgear... get your house in order and fix this. Otherwise, I'm returning this to Costco. I'd rather spend time setting up a new system.
- FarmerBob1Luminary
From having this same issue the last update I did, I:
- Factory Reset all three of my units;
- Power Cycled them;
- Pin-Hole Reset them;
- Went into the RBR when they all came back up, using 192.168.1.1. Can't use the Mobile App since I have a Tagged VLAN PPPOE Login to my Fiber provider;
- Updated the Firmware on all three;
- Pin-Hole Reset all three units;
- Unplugged the two Satellites off after they came back from the reset;
- Manually set up the RBR completely (I've done it so much that I have it all memorized);
- After the RBR was up and running to the Internet;
- Connected the Satellites and made sure they connected and the RBR saw them;
- Sat back and had a beer while I waited for all the clients to jump on . . . ;
- The next day I went into the RBR and checked that all was well;
- Then did my speed tests and whatnot;
- Looked through to see what was attached or not, fixed any of that;
- Waited for any screams when someone tried to do or watch something and it didn't work.
- Hid.
I've been dealing with OEM and OpenSource FWs on all kinds of devices: Routers, Switches, TVs, STBs, Computers, Blu-Ray Players, AppleTVs, Amazon Firesticks, Cars . . . for decades and have found that if you put the time and attention into it in the beginning, you're less likely to have any problems afterwards. Like "Bricked" devices. And it's not really the manufacturers "fault" if the proper process is involved and takes time. It just that's where we are at in technology. I only wish it was a Plug-n-Play World, but it's not. Soon.
- dtayLuminary
If I were to attempt the factory reset route, do I have to reset both the RBR and RBS or just the RBR only? My RBS are hard wired.
Turn OFF the RBS. Just reset the RBR. 15 second press on the reset button then release. Walk thru the setup wizard with a wired PC or laptop and web browser at HTTP and 192.168.1.1.
- BrandX5Initiate
Does anyone know if this will be fixed by a firmware download, and we can wait this out?
- mayechoTutor
This seems to be a problem affecting thousands of users. A factory reset is the only solution working for people that must access the admin section. This is completely unacceptable and Netgear should be honest and open with what they are doing to fix this problem. I have several orbi's across the state and it would be very expensive for me to factory reset each one.
WE NEED A CLEAR STATUS UPDATE FROM NETGEAR.
Any progress on this?
- MikeS2021Aspirant
As of a couple days ago, for me, the issue has gone away. I only noticed an update to the mobile app. Since then, I can control all devices with the mobile app and log into the orbilogin.com site again.
I opted not to do a factory reset as everything continued to technically work and I didn't want to re-configure everything. Hopefully the same solution is rolling out to all users quickly.
