skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this correct?
Also, an AT&T rep told us you have to run a battery and that this is a mobile hotspot, and is suppose to be used not as a stand-along router. So what is this suppose to be used for? We have a small farming business and is used inside the house only. Purchased on the advice of a AT&T rep (independent).
Does anyone have a way to keep the MR6500 from overheating either with a cooling fan or sitting on an AC duct?
Thanks in advance
Steve Kay-Pheasant Hollow Farm
- RidgeRunner1775AspirantExact same issue. The device gets extremely hot and becomes unresponsive. Most of the time the screen will blink on and off before any user inputs can register so I am forced to pull the plug, let it cool down and reboot.
Bettery is out, original power brick and cable, and wifi is off.
The device is unusable in this state. - ArodiDNETGEAR Expert
Hi skaybird and RidgeRunner1775 ,
Can you please provide the below details from Settings>More>Device Information screen on the LCD?
IMEI:
FW Version:
Please also provide the following from the device when you experience the issue.
- Login as admin via the WebUI (http://192.168.1.1). Default password: attadmin
- Open a new tab in the same browser and browse to http://192.168.1.1/model.json
- Copy the contents from the web browser and paste it into notepad or similar.
- Upload the contents to this post.
The MR6500 can be powered ON without a battery. This is the recommended method of operation if you plan to keep it plugged in all the time. Also, please make sure to use the supplied power adapter and cable.
ArodiD
- skaybirdTutor
IMEI:
NTGX65_10.01.47.00
That's it for now. Having difficulty with the upload.
Good morning,
Thank you for reaching out. I do not feel comfortable posting this information on a public forum.
ArodiD RidgeRunner1775 skaybird
I recommend that when that kind info information is needed that you send ArodiD a PM directly so as to keep that information more private. Please avoid posting any MAC/WAN addresses, IMEI numbers and product serial numbers in the forums for security reasons.
- djazzleAspirant
I'm having the same issue. I have the model mr6500 and the constant crashes. The build is from July 2022 and when I check for software updates it says there are none. Can you push an update to my hotspot?
- JohnPengNETGEAR Expert
Could you please explain in detail how you set up M6 to use with your clients?
1. How many clients - WiFi and/or Ethernet?
2. Are there clients keep sending or receiving data?
3. How are the clients typically used, such as streaming, Gaming, etc.
When you feel the device is hot, could you please log in to WebUI and provide the battery temp and device temp under Diagnose page?
Thanks
John
- Not the original OP on this thread, but I am (and have been for the past 2 months) experiencing the same issue. In fact, I submitted a warranty claim with AT&T and received a new Nighthawk M6 today as well and it started with these same issues right out of the box.
*My* device is set up in this way: It is plugged into the outlet using the original AC adaptor and USB C cable with no battery, running only on AC power. Wifi is disabled on the device and it is piping out of the Ethernet port to a more powerful Netgear router for whole house usage.
There are at least 6 clients on the Netgear router all using various devices for streaming/downloading/browsing/gamimg/household use.
I need to enable WIFI from the device directly to see the temp. Per the WebUI, the device begins to stop responding (screen freezing, internet failing) at about 47°C. When operating in AC mode, the temperature climbs rapidly from 35°C to 47°C in a matter of minutes. There is no battery temp as the battery is not in the device.
This is on current firmware version NTGX65_10.01.47.00- JohnPengNETGEAR Expert
Please provide the model.json file and send PM to me.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
- zbrown8482AspirantI am having the exact same issues. I purchased the unit brand new in August 2022 and about 2 weeks into using it the unit would go unresponsive and unable to use the screen when it got hot. Unit is plugged in without the battery in it and using the ethernet cable. Unit will not work until unplugged and has cooled down. Are there any fixes to this issue yet?
- Ive found that not letting the screen go to sleep and keeping the battery in it (even though its not good for the battery) helps, but it still will overheat and freeze eventually. Other than that, no permanent or absolute solutions so far. John Peng is very helpful so far, I just sent him some info from my device when it failed so hopefully that will help him.
zbrown8482 wrote:
I am having the exact same issues. I purchased the unit brand new in August 2022 and about 2 weeks into using it the unit would go unresponsive and unable to use the screen when it got hot. Unit is plugged in without the battery in it and using the ethernet cable. Unit will not work until unplugged and has cooled down. Are there any fixes to this issue yet?Could you please specify in details how you use the device?
1. Are you using ethernet port?
2. How many WiFi clients are connected to the device?
3. How heavy data are used on each client?
4. How long does it take for the lockup to happen?
5. Can you log in to WebUI to check what is the device temperature when the lockup happens?
6. What is the carrier SIM you are using, AT&T or Firstnet?
Thanks
John
- zbrown8482Aspirant1. I am using the ethernet for a work computer
2. Usually during the day only one cell phone is connected to the wifi but typically isn't in use during that time
3. Unsure about the amount of data that is being used but believe it is heavy data usage. I am not the one home at the time. It is my spouses work computer. Typically the unit won't work until 7:45 am and that is leaving it unplugged and off overnight and it won't connect to any device until it's been reset one or multiple times after the 7:30am mark.
4. It varies on when it locks up sometimes right away and sometimes it lasts 10hrs. I haven't found an exact rhyme or reason yet
5. I have not been able to use WebUi yet because I am not home when it happens.
6. Firstnet
Thanks for reporting the issue on the community. After checking with the internal team, I can confirm that the issue is related to using the device without battery. We have a fix for this already. We are going to submit the release to AT&T get their approval before releasing it.
I will keep you posted on the progress. For now, you can work around the issue by using the battery as Kartoffelkonig9 suggested.
Regards
John
- JohnPeng
Thank you for the update. Hopefully AT&T will approve the fix sooner rather than later. Even with the battery still in the device, its overheating, it just seems to happen less often. The last two days were actually relatively stable for me, but it just overheated again 3 times in the last two hours.
Is it an issue with the device itself or with the firmware? If you can answer or happen to know.
- qaidforAspirant
If your router is hot to the touch, it could be a sign that a firmware update is needed. If that doesn't do the trick, you might need to add a cooling element—especially if you're working it hard. Generally, you want router temperature below 90 degrees Fahrenheit.
- Scoe-zTutorIt's above 100 by just turning it on and not connecting a device. I will try a fan.
- MrspethelInitiateI am having this same issue. Any update on when the firmware will be available?
- qaidforAspirant
could you please log in to WebUI and provide the battery temp and device temp under Diagnose page forpc.onl youtube vanced for pc
- MrspethelInitiate30c device and 32c battery with a two server fan wind tunnel. Without the wind tunnel it was 47c-50c and on a warranty replacement device. I’d hoped it was solely a temp issue. Running battery, plugged in, WiFi only (no Ethernet).
- Scoe-zTutorIs it working?
- Scoe-zTutor
I don't have the battery in, and the device temp sits at 48 - 53 C.
Yesterday I hooked up a pc fan and remove the bottom cover from device then sat the device on the fan. Now it stays at 29 - 33 C. So far it hasn't crashed. I will see how today goes. Oh, and I'm using ethernet.
Thanks for the update. Please keep us updated on your testing.
Thanks
- georgebanhamAspirant
Nighthawk M6, MR6110, Battery out plugged into AC home, no wifi for any other devices. just purchased, Supplier/Telco does not answer phone. Help please Thanks
- Scoe-zTutor
Does it connect to the cellular network?
Please check whether you see WiFi icon has zzz on it after device boots up. If the zzz overlay doesn't disappear after 1 minute of device boots up, please do a factory reset. If the issue is persistent, please get the a replace device.
Thanks
John
AT&T approved the maintenance release to address the data disconnection and Firstnet related issues. The updated has been posted on the AT&T upgrade server. Please do a manual upgrade check if you would like to get the update sooner. But the upgrade will be gradually released to all the devices.
Thanks
